Old 31-01-2007, 02:18 PM   #1 (permalink)
Default Which is best?
Hi Guys,
I am in India. I would like to buy an Internet Security Software. Can you recommend me the cheap and best one out of your experience? The Software should consume more space,I mean, the System should not become slow on using the Software.
kumarn_2004 is offline
Old 31-01-2007, 02:30 PM   #2 (permalink)
Kiran.dks's Avatar
Default Re: Which is best?
I suggest Kaspersky Internet Security Suite.
Kiran Kumar R
Kiran.dks is offline
Old 31-01-2007, 02:49 PM   #3 (permalink)
The High 5 Flyer
sam9s's Avatar
Originally Posted by kumarn_2004
Hi Guys,
I am very much satisfied with avast!. Its both an antivirus and internet security tool, and the best part is its completely free!!!!!
sam9s is offline
Old 31-01-2007, 02:52 PM   #4 (permalink)
Kiran.dks's Avatar
Yep! avast! is the best solution when it comes to free version.
Kiran Kumar R
Old 31-01-2007, 04:27 PM   #5 (permalink)
Romeo + Lucifer = ME
codename_romeo's Avatar
Kapersky
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
codename_romeo is offline
Old 31-01-2007, 05:29 PM   #6 (permalink)
You gave been GXified
gxsaurav's Avatar
1st of all, wrong section
2nd, use Norton Internet Security 2007 if u have more then 512 MB RAM & want an idiot proof Internet security solution
Else use Kaspersky internet security, u will need to learn & configure it a bit, but it lighter then NIS 2007 on system resources
about.me/gxsaurav
gxsaurav is offline
Old 31-01-2007, 08:01 PM   #7 (permalink)
shantanu's Avatar
Is it necessary to use AV or IS !!! i rely on windows firewall and defender
shantanu is offline
Old 31-01-2007, 10:52 PM   #8 (permalink)
premsharma's Avatar
I don't think it is necessary to use any antivirus. They are all same. Norton the worst, hogs resources. If at all you want to use, use some light one like avast or bit defender and rely more on firewall [kerio etc].
Gamers can not afford to use any antivirus. After all instead of securing, it returns troubles than anything usefull.
Use some disk imaging utility like norton ghost to back up ur OS and restore as and when you feel some virus might have sneeked through ur firewall. After all restoration takes only 5-10 min.
premsharma is offline
Old 31-01-2007, 11:03 PM   #9 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
COMODO firewall, AVG Antivirus. u r safe. Both free.
koolbluez is offline
Old 31-01-2007, 11:07 PM   #10 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
Wrong Section>> Move It
Kaspersky
wizrulz is offline
Old 31-01-2007, 11:53 PM   #11 (permalink)
Arsenal_Gunners's Avatar
Hi Guys,
Hi,
Me too in India.I would definitely say Kaspersky is better than most of them out there,if you are ready to buy that is.
If you want something for free get ZA.
Arsenal_Gunners is online now
Old 01-02-2007, 02:15 PM   #12 (permalink)
Hi koolbluez,
I am using Firewall from Windows XP Home Edition(SP2). Your recommendation is COMODO firewall along with AVG. I think only one Firewall should be used on any system. So, If I attempt to use COMODO firewall, then I should leave Windows Firewall. Is it OK or what? Is COMODO firewall is better than Windows Firewall in all respects? Your opinion. Can you give me the link for COMODO firewall so that I may download it with it?
Old 01-02-2007, 03:13 PM   #13 (permalink)
Sup' dude, Sup'
Kaspersky is better than any other anvirus/firewal software. Moreover it's light on resource. Even cnet says it's the best as of now.
ambandla is offline
Old 07-02-2007, 07:04 AM   #14 (permalink)
Hi koolbluez,
Hi Guys,
May I use Windows Firewall and COMODO firewall together on my System? May I disable the one I like if the above two are on my system? Any problem and what are the setting to be changed for the purpose?
Old 07-02-2007, 07:45 AM   #15 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
Disable Windows Firewall... it sucks.
Disable Windows Firewall in Windows XP SP2
Note A firewall is designed to help protect your computer from attack by malicious users or by malicious software. Malicious software includes viruses that use unsolicited incoming network traffic to attack your computer. Before you disable your firewall, you must disconnect your computer from all networks, including the Internet. To do this, follow these steps:
1. Click Start, click Run, type Firewall.cpl, and then click OK.
2. On the General tab, click Off (not recommended), and then click OK.
Disable Internet Connection Firewall in Windows XP or Windows XP SP1
1. In Control Panel, double-click Networking and Internet Connections, and then click Network Connections.
2. Right-click the connection on which you want to disable ICF, and then click Properties.
3. On the Advanced tab, click to clear the Protect my computer or network check box.
If u didn't get it.. here's the method with pics...
Another one
Comodo firewall link
