Old 30-01-2007, 01:37 PM   #1 (permalink)
Default Using 2 internal HDD's
Hello,
I wanted to know whether I can use 2 HDD's on my computer.
I currently have a maxtor 40gb drive.
My mobo is MSI MS 7057
Please help,
Vinith
vinith98 is offline
Old 30-01-2007, 05:52 PM   #2 (permalink)
Eazy's Avatar
Default Re: Using 2 internal HDD's
Originally Posted by vinith98
I wanted to know whether I can use 2 HDD's on my computer. I currently have a maxtor 40gb drive. My mobo is MSI MS 7057
I ran your MoBo thru Google and it took me to this page...
http://www.msi.com.tw/program/produc...il.php?UID=587
it is mentioned on this page that this board supports 4 IDE drives.
Eazy is offline
Old 30-01-2007, 05:57 PM   #3 (permalink)
Waiting for 3 Miracles...
saurav29's Avatar
yes you can....
if you need help installing it.... say so will post you a tutorial.....
peace
raj
saurav29 is offline
Old 30-01-2007, 06:26 PM   #4 (permalink)
The High 5 Flyer
sam9s's Avatar
Hello,
Please help,
Vinith
Yes you can easily. The IDE cable connected to you maxtor must be having two connectors, you can connect another HDD by making it primary slave with your maxtor as your primary master. To make it primary slave all you need is to remove the jumper(for segate for samsung settings r different). (In case you do not know what jumper is refer the following link.)
http://www.pcguide.com/ref/hdd/op/jump-c.html
Once that is done you BIOS should automatically detect the HDD and you should see the drive in the explorer.
sam9s is offline
Old 31-01-2007, 01:36 AM   #5 (permalink)
Still in war with allies
ssdivisiongermany1933's Avatar
I have connected three hard drives and no problems
ssdivisiongermany1933 is online now
Old 31-01-2007, 04:26 PM   #6 (permalink)
Romeo + Lucifer = ME
codename_romeo's Avatar
u should be able to plug in the additional hdd(with proper jumper settings)and use it.
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
codename_romeo is offline
Old 31-01-2007, 05:10 PM   #7 (permalink)
Eazy's Avatar
If the drive is new and has not been used before than Windows Explorer may not recognise it until you start Disk Management and here Intialise\partition\format and ensure the drive has a Drive Letter.
Eazy is offline
Old 31-01-2007, 06:03 PM   #8 (permalink)
Than for replying guys. Ya please leave a link for a tut.
thanx again,
Vinith
vinith98 is offline
