Usually when I used to Standy the Computer by selecting it from the Shutdown Menu, the fans(CPU and SMPS) would shutoff and the system would come to a low power state with the Power Led blinking. Pressing the Power button again would bring it out of standby..
Recently I installed XP again, and now whenever I standby what happens is the screen would simply shut off and nothing else. The CPU and the keeps on running.
Help me sort it out..
__________________ Simplicity is the ultimate Sophistication HP dv6 6121tx: Core i7 2630 QM | 4GB | AMD 6770M 2GB GDDR5 | 640 GB
Nokia N86 8MP
No, Its a Pentium 2.4 with ASUS P4GE MX motherboard. There was no problem with it till now and I think I might have changed some settings accidentally.
Now what to do?
Nokia N86 8MP
you can go to bios and check if you changed any thing in power options or i think you must have done some Drivers update and that power options vanished after that
I haven't done any Single motherboard Drivers update. I don't change anything in the BIOS except the Boot Sequence. I cleared the BIOS twice now, but nothing is happening
Is it some problem with Windows?
Nokia N86 8MP
i is not a problem if your system is resuming correctly, i had this problem in AMD but after installting Cool n quiet drivers it solved , so i think windows power management error only
