Old 29-01-2007, 11:54 PM   #1 (permalink)
Jags's Avatar
Question view PC on TV..???
hi..
i want to direct the output of my PC on to a Plasma TV (obviously quality is a BIG issue)..
can u tell me how can i do that ..
thanx
Jags is offline
Old 29-01-2007, 11:58 PM   #2 (permalink)
shantanu's Avatar
Default Re: view PC on TV..???
do you have a dedicated graphic card in your system . if yes then tell the model no. if not then you got to purchase one from a shop and use its TV out feature ..
shantanu is offline
Old 30-01-2007, 12:04 AM   #3 (permalink)
Jags's Avatar
nope.. no graphics card in my system
can u suggest a nice graphics card..how much wil it cost yaar..???
Jags is offline
Old 30-01-2007, 12:05 AM   #4 (permalink)
shantanu's Avatar
tell your system specs .. then only we can suggest !!!
shantanu is offline
Old 31-01-2007, 10:08 PM   #5 (permalink)
Jags's Avatar
my system specs r:-
p4 3.06 GHZ
n 256 MB ram
can u plz suggest a decently priced graphics card..??
all i want from the graphics card is to connect my PC to TV..THATS IT
thanx
Jags is offline
Old 31-01-2007, 10:12 PM   #6 (permalink)
shantanu's Avatar
Again NO Motherboard Information!!!
your Graphic card will run only on your Motherboard!!
So whether it is having a AGP slot or not.. that is to be seen
shantanu is offline
Old 31-01-2007, 10:19 PM   #7 (permalink)
Google Bot
Pathik's Avatar
yea man... give complete info here...
Pathik is offline
