Old 29-01-2007, 02:10 PM   #1 (permalink)
Call me Sumit
esumitkumar's Avatar
Unhappy IEEE 1394 port not recognized in new ASUS M2NPV-VM Socket AM2
Hi
I have a fully fine working AMD 64 bit PC with ASUS M2NPV-VM Socket AM2 MB. It has 1394 port enabled in BIOS as well as cable is connected inside the ATX cabinet too...still it cant recognize my canon MV850i camcorder ...by firewire cable
Can anybody help plzzzzz....
esumitkumar is offline
Old 29-01-2007, 02:31 PM   #2 (permalink)
Default Re: IEEE 1394 port not recognized in new ASUS M2NPV-VM Socket AM2
Not sure, but does it require a driver to be installed? If so them that might be the problem.
Install the driver.
ranjan2001 is offline
Old 29-01-2007, 02:46 PM   #3 (permalink)
Call me Sumit
maybe...lemme chk
Old 29-01-2007, 03:02 PM   #4 (permalink)
^^Does the firewire port show up in network connections?
C2D E8400@3.8, P5N32-E SLI, 2GB Cellshock DDR2 1000(4-4-4), 8800 Ultra SLI, 2.7TB storage, CM Stacker 830, TT 1200W, Dell 2005FPW, Lots of Audio HW.
Ch@0s is offline
Old 29-01-2007, 03:55 PM   #5 (permalink)
Call me Sumit
No Chaos.it doesnt show in network connections .......
Old 29-01-2007, 04:38 PM   #6 (permalink)
Wire muncher!
infra_red_dude's Avatar
must be a driver issue. check the driver and see if resourcers (like irq etc.) are available to the controller. also check if the cable from the port to the motherboard is connected correctly. many a times it may haf many individual connectors not connected correctly! use a software like everest to see the system properties and whether it detects it. also configure ur video capturing software to search for the device on firewire port. many a times the default is usb.
infra_red_dude is offline
Old 29-01-2007, 04:51 PM   #7 (permalink)
digiFriend's Avatar
check in "device manager". and it will also show in "network connection"
you never know what you can do until you try
digiFriend is offline
Old 29-01-2007, 04:53 PM   #8 (permalink)
digiFriend's Avatar
network connection image
Old 05-02-2007, 03:15 PM   #9 (permalink)
Call me Sumit
bhai logo..i tried everywhere..it shows in n/w connections as well as device manager "TEXAS INSTRUMENTS OHCP 1394 NET ADAPTER" still when I connect my canon MV850i camcorder ...it doesnt detect anything...
same is the result when I tried it on my friend's PC
plz help
Old 05-02-2007, 08:17 PM   #10 (permalink)
seems that you may have some switch/mode to change on the camera to make it detected as a device, I remember my friend having such problem on usb port, later I found that there is a mode on the camera which if not selected it wont show & get detected as a USB device.
Is the same applicable with ur camcorder?
Old 05-02-2007, 11:04 PM   #11 (permalink)
The High 5 Flyer
sam9s's Avatar
He is connecting using IEEE and not USB.
__________
plz help
Try connecting on a different port or changing cable. Which IEEE cable are you using.......4-6
Check this thread out might help.....
Camcorder USB to Firewire to Video Capture/Editing: Possible?
sam9s is offline
Old 06-02-2007, 07:56 AM   #12 (permalink)
Yes I know, I gave that specific USB example of my friends camera.
Point I am making, does the camera has switch to make it detected as a device then that has to be switched on.
Old 06-02-2007, 10:09 AM   #13 (permalink)
Call me Sumit
Ya I am using 4-6 cable ...I will try changing the cable ..but I wonder same cable was working fine with my old PC...
No yaar..camera doesnt have any switch like this..You have to turn it on and just play the movie recorded ...thats it..
Thanks for all suggestions...
Old 06-02-2007, 03:51 PM   #14 (permalink)
The High 5 Flyer
sam9s's Avatar
Nope camm doent have to switch to any mode to be detectable. You just switch it on and should be detected.
mmmmm so you were able to use the camm with your old PC. Any drastic h/w or s/w changes, like maybe XP SP2, just trying to narrow down things.....
Try reinstalling the driver through your mobo cd as well........
sam9s is offline
Old 07-02-2007, 01:02 AM   #15 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
There was one patch for FireWire for Windows XP Sp2 .. Try installing that and see if that helps.
http://support.microsoft.com/kb/885222
Also search MS KB for FireWire ..
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 07-02-2007, 11:53 AM   #16 (permalink)
Call me Sumit
Ya I had changed my whole PC...Its AMD 64 bit 3600 + , 1 GB RAM, ASUS M2v NVVM MB and Win XP Pack 3.....Earlier it was P-III 700 MHz, 810 MB and 128 MB RAM with Win 98 ...
Also I have SATA 2 disk now and I think I cant install Win 98 on it
Old 07-02-2007, 02:28 PM   #17 (permalink)
digiFriend's Avatar
plz help
then your question should be "camcorder not detected".
as your ieee 1394 port is already recognized.
some camcorder has to select output in its Menu " USB 2.0 or Firewire"
try to restart pc after camcorder is connected.
Old 20-02-2007, 04:53 PM   #18 (permalink)
Call me Sumit
I have tried everything..there is no driver on canon site for XP...plz help
Old 20-02-2007, 07:06 PM   #19 (permalink)
assasin's Avatar
Didnt they supply a driver cd along with the cam when u bought it?
assasin is offline
Old 20-02-2007, 07:18 PM   #20 (permalink)
Contact ur local canon dealer /service center , they should be able to help out for sure.
Old 21-02-2007, 10:57 AM   #21 (permalink)
The High 5 Flyer
sam9s's Avatar
cant seem to narro down.......there is a complete overhall in the system.......I guess you were using a dedicated firewire card in your old system, coz a P-III board would not be having an inbiult one. Try plugging that IEEE card in your new system. Disable the onboard one from bios install the new one. I dont think you would even be needing drivers for the dedicated card as you already have xp sp2, still keep in hand, incase needed. After card instillation try plugging the camm and see if it gets detected on the dedicated card.............
sam9s is offline
