Old 28-01-2007, 07:11 AM   #1 (permalink)
Cool GEttin A New Pc ???
Hmmmmmm .....
Guys, I Wanna Make A Mid Budget - Rock Good Sense Pc, But I Am Lookin 2 Constraints.
1. This Pc Wud Be An Absolute Budget Pc. So No Core 2 Duo.
2. I Wanna Upgrade This New Pc To Core 2 Duo Within Next 6-8 Months, When Prices Come In Range Of 8-9,000 For E6600. So Pls Help Me So That Most Of What I Shud Buy Today, Shud Be Easily Fitting Into The New Core 2 Duo That I Wanna Upgrade Later.
So What'S Up ---
I Want Right Now -
Amd Athlon 64 3500 --
-> Tell Me Why Shud I Buy Am2 & Not Socket 939 Of Amd3500. Any Advantages. I Know That Ddr2 Is Only Compatible Maybe With Am2 Model Only N Not With 939, But A Little Faster Ddr2 Is Not That Worthy Than Ddr - My Guess. Or Tell Me If I Am Wrong. .............. Just Help Me Ppl.
Ok This Is My Current Built Up.
I Will Add N Change As U All Like, But Tell Me The Reasons.
Amd 3500 Socket 939 ( Other Options -- Amd 3500 Am2 / Amd 3200 Am2 / Amd 3200 939 )
Seagate Baracuda 320 Gb Sata2 ( Other -- Seagate 320/300 Gb Sata / Wd 300 Gb Sata2 )
1 Gb Ram ( Ddr2 Or Ddr - Which Is Better ??? ) ( Transcend Or Corsair - Tell Me )
Dvd Write Drive ( I Am Complete Noob In This Choice - I Havent Had Any Experience In Dvd Drives - Just Tell Em Ur Experience ) ( I Think -- Benq / Nec / Liteon / Liteon Lightscribe )
Rest All Is Nothin Left - 1 Extra Fan, Win Xp Sp2 + Tiny Xp Experience Edition + Adv Server 2003 - Dual Boots )
Monitor - I Have Already
Mouse - Best Reasonable But Very Ultra Light To Use N Some More Advance Configurablity - But Inside 500 Bucks.
My Whole Budget, Excludin Monitor, Keyboard, Speakers Is Bout 20,000 +-2,000 Bucks. Ofcourse, Inr Rs.
N Yes - I Missed - Tell Me Which Mobo - I Dont Play Most Latest Games, So Anythin Absolute Budget Will Rock Still - Nvidia 6100, 6200 Is Fine, Inbuilt Integrated Video N Sound - I Have Used Asus A8Nvm With Integ. Video - Nvidia 6100 N Its Fine For Now - Till I Get My Hands On The King Kong Core2Duo.
Sorry For The Long Post But I Need All Ur Help N Be Quick - Time Is Runnin Out.
Just 1 More Mention - I Want As I Told Ye, I Wanna Keep Most Of This Pc, Easily Upgraded Into A New Core2Duo, So Except From The Cpu N Mobo, All Shud Be Absolute Same With The 2 Pcs. Ie. Ram, Hard Drive Etc.
=============== Anyone With Prices In Probably Delhi - Wud Be Another Gr8 Help.
Now Do It. ........
Thx
XtremeFuturistic is offline
Old 01-02-2007, 02:58 AM   #2 (permalink)
shantanu's Avatar
Default Re: GEttin A New Pc ???
you can go for 512 ram
160Gb sataII seagate or wd
a good cabinet and 450 watt SMPS
and a DVD-writer (sony)
am2 is more advanced then 939 check this out :
http://www.amd.com/us-en/Processors/...5e9493,00.html
shantanu is offline
