Old 27-01-2007, 11:55 PM   #1 (permalink)
moshel's Avatar
Default Buying a Car Audio System
hey guys m gonna buy a new car so need suggestions for a good system..........i demand more clarity than loud music and high bass....my budget is 15k......i checked websites of sony and pioneer but m confused....
for eg. is the cd panel and speakers are to be purchased separately?....so that i can choose any cd panel and any speaker?
pls give me details with model names if possible.....cos i dont want a thread which will become Pioneer vs. Sony vs. etc etc.
moshel is offline
Old 27-01-2007, 11:57 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: Buying a Car Audio System
i ve heard blaupunkt r d best
Pathik is offline
Old 28-01-2007, 01:44 AM   #3 (permalink)
crystalboi's Avatar
yes dude go fr Blaupunkt for speakers, Pioneer for your CD player,n for woofer SONY or Kenwood...n yes just do get the AMP if you go for woofer, in 15K u can explode neone....
dont buy CD player of SONY there lens gets weak sooner...rest you may change according to availabilty and cost...good luck!!!
The stupid neither forgive nor forget. The naive forgive and forget. The wise forgive but do not forget
crystalboi is offline
Old 28-01-2007, 04:36 AM   #4 (permalink)
hailgautam's Avatar
Once did a Stock Audit of Blaupunkt (It means the Blue Point). They have great range.
Change is Nature, the part that we can influence; and it starts when we decide.
Where you going?
With Luck forward.
hailgautam is offline
Old 28-01-2007, 09:30 AM   #5 (permalink)
moshel's Avatar
hey guys wat do u think abt JVC? .........btw pls answer me, will i have to purchase the head unit and the speakers separately?............
moshel is offline
Old 28-01-2007, 12:17 PM   #6 (permalink)
pedal to metal
suave_guy's Avatar
blaupunkt is good but u can get better speakers than that...like JBL, infinity kappa, hertz and pioneer
well for ur demand and budget i wud suggest a pioneer cd player and JBL rear 6X9 coaxials...for fronts go for whatever pleases ur ears in 4" sizes...like pioneer, sony or whatever
ur budget is too low...u cannot get amp and components(for front sound) in this budget which wud have guranteed u high clarity sound...
i wud suggest that dont invest too much in fronts rt now and once u've extra 15K to spend go for components and an amp...
rem that the key to a quality car audio system is to project front sounding soundstage and not the rear one which most of the ppl do, rear speakers should always play a supporting role....and to achieve that u got to install components in front and an amp...
good luck!
ENjoy...
your "attitude" is your best friend...
suave_guy is offline
