Old 27-01-2007, 03:40 PM   #1 (permalink)
Default hArdWare Detection
IS there any procedure to dectect Hardware eg. camera ,sound card,etc through OS without opening case and before installing drivers.
ismart is offline
Old 27-01-2007, 03:44 PM   #2 (permalink)
Arsenal_Gunners's Avatar
Default Re: hArdWare Detection
use the add new hardware wizard in control panel.
Arsenal_Gunners is online now
Old 27-01-2007, 05:52 PM   #3 (permalink)
The Transcendental
Or if you are taking about diagnostics try Sisoft Sandra.
There are many more tools depending on your needs.
:::::::::: When freedom is outlawed, only outlaws will have freedom ::::::::::
..:: Free Radical ::.. is offline
Old 28-01-2007, 12:56 PM   #4 (permalink)
Are these tools works when i have not installed drivers..
ismart is offline
Old 28-01-2007, 04:53 PM   #5 (permalink)
The Transcendental
Gee. Never tried without drivers. But i see no reason why they shouldn't. I mean diagnostics are there to help us identify the hardware using its ports/sockets. Drivers may be needed however if you need to get a better idea of benchmarks.
Old 29-01-2007, 02:29 AM   #6 (permalink)
shantanu's Avatar
if your hardware is detected by windows as unknown devices then these softwares will also detect them as unknows device.
shantanu is offline
