Re: Life of.....
LCD/TFTs also suffer from dead pixels.
Can be due to age or otherwise.
They are also not covered under warranty.
Plus, the monitor loses resale value in such conditions.
Be certain to check for these when you are buying a new monitor.
As a rule, cheapos develop dead pixels with greater ease.
P.S. Your colored mobile is also prone to develop such problems.
As such the frequency of dead pixels is variable and don't necessarily mean your monitor is dying. but they are irritating if noticeable and cannot be repaired.
CRTs, you can tell when the picture tube starts failing to deliver , you get all sorts of problems with color, brightness or contrast ; picture may be shaky or it just dies all of a sudden.
CRT picture tubes usually last 7 years or so and certainly die after 10 years(more often than not).
LCDs manage 10 years plus without many problems (if its branded).
:::::::::: When freedom is outlawed, only outlaws will have freedom ::::::::::
