nothing happens when i click on my dvd driver .. it shows that i dont hav a DVD in it although i do have a DVD in it .. & when i try ejecting it , nothing happens even when i manually press the eject button..1 thing more it shows "DVD RAM drive" I am sure it was something else before like 'SONY DVD RW DW GW102A' .. thats wat i see in the device manager
I have faced this problem before & it would ressolve by itself on reboot but now its persisting
thanks in advance
oh mines a DVD writer so i can watch n burn cds & DVDs .. thats called combo right??
well i just hav 1 DVD writer thats it .. no other writer.. if thats wat u wanted 2 ask..
& how d i check my leads and jumfer settings??
NO THATS DVD-RW NOT A COMBO,, COMBO CAN ONLY READ DVD's NOT WRITE THEM,
OPEN UP YOUR CABINET AND SEE YOUR DRIVES lead and power connector which joins in the back of your drive,,
now see you drives back it should have a jumfer attached to it a small platic tip like structure which will be joining two pins in three pins set. it will be on the first pin set check it.
i am sorry .. i didnt get that .. can u b a little more precise pal? i see two things going in the back of my DVD writer .. 1 what if i am not wrong is called a databus (from motherboard) n another switch/plug (from the powersupply)
try pulling them out and plugging in again and do that one by one > means first the power cord and then the data cable.
After that take out the data cable from MOBO and insert it again.
IF you have another cable like that then try changing it.
NOW look deeply > You will find 2 x 3 pin sets like this : : : just on the right side of where you plugged the data cable on mobo.. see if any pins are shorted with a plastic jumfer like this > can be in three different positions
1> : - : [- is your shorted jumfer]
2> - : :
3> : : -
NOW IF YOU have a single drive then it should be a master so the third one is correct.
if two drives then second one is second one is correct.
IT IS ALSO POSSIBLE THAT NO JUMFER ARE SHORTED THERE
i should disable my DVD writer before i do that right??
or u want me to turn my pc off completely?? i guess if i m taking out the data cable from the MOBO i ll hav to turn the whole pc off.. i ll try this tomm n let u know but thanks for posting
yes it is .. this is wat the last thing i saw in BIOS
Pata primary master : samsung SV0411N
Pata secondary slave: SV0402H
Para secondat master: sony dvd rw G120A
__________
& 1 more thing .. it is detecting the drive as in a DVD RAM drive but its not even ejecting it & when i press the eject button i do see a green light which blinks for a while n then disappears
Reason: Automerged Doublepost
yea i am going to lamington tommorow for some other work .. does any1 here know where the sony service center for DVD writers is? n the writer is out of warranty
These Problems happened to me many times before with my SONY drive whenever I tried messing up with some themes for XP. The problems where CD not ejecting, Autoplay not running and more...There is absolutely no problem with your Drive. Simply install Windows XP again, and I am sure, it will be all right.
__________________ Simplicity is the ultimate Sophistication HP dv6 6121tx: Core i7 2630 QM | 4GB | AMD 6770M 2GB GDDR5 | 640 GB
Nokia N86 8MP
installing XP will take me like 30 mins & then i ll hav to install many programs again!! any other way?? can't i just install some drivers?
__________
cmon any1?? the thing is installing XP just takes half an hour but to reinstall all the programs n the games it will take me like 18 hrs!! help!!
Ok, Try this.
Goto control Panel->System->Hardware->Device Manager
Select your drive and Uninstall it.
Now restart your system. Windows will detect the drive and will install necessary drivers. Finally goto Control Panel->Administrative tools->Computer Management->Disk Management.
Right click on your drive and Change the drive letter to something else.
Note: Changing the drive letter may make some games not work...
Nokia N86 8MP
If all the methods fail, go for installing Windows again. Soon after installing Windows and all the necessary drivers and updates, backup C: drive using Acronis true image or R-Drive image. The next time you have to install Windows it will take only 5 minutes to restore from backup. You can save your time....
Nokia N86 8MP
