Old 25-01-2007, 02:58 PM   #1 (permalink)
Exclamation INTEL Motherboard for P4 HT 3.00 GHz under Rs. 7000
I want a intel motherboard for P4 3.00 GHz(HT) with 800/1060 MHz FSB under Rs 7000/-. It must allow me to install the OS on a sata HDD dirctly without any driver or third party utility.
Is there any 965 based board from MSI or GIGABYTE suitable for my budget ?
bharatesh is offline
Old 01-02-2007, 03:43 AM   #2 (permalink)
shantanu's Avatar
Default Re: INTEL Motherboard for P4 HT 3.00 GHz under Rs. 7000
Visit www.intel.com
shantanu is offline
Old 02-02-2007, 01:39 AM   #3 (permalink)
Fighter's Avatar
Your choices can be
Intel D101GGCL - Rs.3,125/-
Intel D102GGC2 - Rs.3,610/-
Intel D946GZIS - Rs.4,094/-
Intel DG965WH - Rs.5,723/-
Fighter is offline
Old 02-02-2007, 01:48 AM   #4 (permalink)
Still Shining!
Lucky_star's Avatar
Originally Posted by Fighter
Your choices can be
That Intel D102GGC2 motherboard has got ATI Radeon X200 series onboard graphics, which is much better than a 965. Plus it has PCIe slot, SATA and DDR2 capable. More info here
Nokia N86 8MP
Lucky_star is offline
Old 02-02-2007, 01:50 AM   #5 (permalink)
shantanu's Avatar
yeah X200 chipset is a mind blowing chipset from Ati and even its onboard can be compared to a 6200 ..
so gives great graphics... and with DDr2 support its futurly and SATA support
with PCie as tols by Lucky_star
shantanu is offline
Old 03-02-2007, 11:53 PM   #6 (permalink)
El mooooo
eddie's Avatar
You are probably confusing 965 with 950 or 945. Intel G965 based boards have X3000 graphics adapter which supports Pixel and Vertex Shader 3.0, upto 384MB graphics RAM support and hardware acceleration. ATi X200 is no match for a Intel X3000.
eddie is offline
Old 03-02-2007, 11:57 PM   #7 (permalink)
Still Shining!
Lucky_star's Avatar
^^Mayb, but games like NFS carbon, Doom III plays better in the ATI X200 than the X3000 here.
Nokia N86 8MP
Old 04-02-2007, 02:23 AM   #8 (permalink)
a_g = JPKN
s18000rpm's Avatar
Your choices can be
WTF
i bought intel dg965wh for $135, frm USA just a month back, in rupees its ~6000 bucks.
the 965RY retails at 7-7.5 k, & WH has more features in it, like dolby, 7.1, ViiV tech....
so i think you quoted the price wrong
ASUS K53SV SX520D + BF3
s18000rpm is offline
Old 04-02-2007, 02:23 AM   #9 (permalink)
El mooooo
eddie's Avatar
Have you checked that you have X3000 and not just 3000? Q965 boards have 3000 while G965 have X3000...it is a HUGE difference between two.
eddie is offline
Old 04-02-2007, 02:25 AM   #10 (permalink)
a_g = JPKN
s18000rpm's Avatar
but still the Final version of the Drivers hasnt been released.
btw Intel themselves stated that GMA X3000 is not for gaming but to run Vista Premium/Ultimate @ its fullest.
Old 04-02-2007, 02:49 AM   #11 (permalink)
El mooooo
eddie's Avatar
I have not read what they said but even if they did...they didn't say anything wrong. You are buying on-board graphics for god's sake...what do you want to run? Doom 3 at 2048x1024?
eddie is offline
Old 04-02-2007, 07:52 PM   #12 (permalink)
shantanu's Avatar
Onboard graphics have some limitations you cannot overload them with high resolutions.. they will heat up and will slow down and its not meant that if its ATi or Nvidia onboard then it wont heat up... it has limitations you cannot exceed them....
shantanu is offline
Old 04-02-2007, 07:59 PM   #13 (permalink)
a_g = JPKN
s18000rpm's Avatar
dude, i think you do know there's a BIG difference between a gaming Onboard & non Gaming onboard.
all Intel onboards are of later purpose. they're specifically designed to run the OS & other applications (video...) without the need of dedicated card. & not for gaming.
ATi & Nvidia come in former one, they are desinged to do all the stuff which basic onboard (Intel) does & also run games.
if you tried to play NFS Carbon on GMA950, you'll know what i'm talking about.
while the same game runs Smoothly (@ low settings ofcourse) on ATi & Nvidia onboards.
Old 04-02-2007, 08:10 PM   #14 (permalink)
shantanu's Avatar
yeah thats true .... on low settings
shantanu is offline
