Old 25-01-2007, 09:12 AM   #1 (permalink)
Still in war with allies
ssdivisiongermany1933's Avatar
Smile Ipod portable Speaker
I want to Purchase portable speaker for my I-pod video 30 GB ,My budget is upto Rs 3500 .are there any I-pod speaker in this range .Pls help it's urgent
ssdivisiongermany1933 is online now
Old 25-01-2007, 07:36 PM   #2 (permalink)
Tech Geek's Avatar
Default Re: Ipod portable Speaker
Do you want battery powered ones or AC only ones
Tech Geek is offline
Old 25-01-2007, 07:48 PM   #3 (permalink)
kumarmohit's Avatar
If he asks for portable IMHO they must be battery powered
kumarmohit is offline
Old 25-01-2007, 07:58 PM   #4 (permalink)
Tech Geek's Avatar
My mistake
BTW
it is impossible to get good speakers for 3.5K
you will need to spend atleast 5-6K
Old 26-01-2007, 02:16 PM   #5 (permalink)
pedal to metal
suave_guy's Avatar
check out the altec IM series if u want quality...they are the best in business
ENjoy...
your "attitude" is your best friend...
suave_guy is offline
Old 26-01-2007, 02:26 PM   #6 (permalink)
The Devil's Advocate
iMav's Avatar
i hav seen some decent ones in and around 3 to 3.5 k here in mumbai ... if my memory is correct then they were of 'yes'
http://beingmanan.com
iMav is offline
