Old 24-01-2007, 06:30 PM   #1 (permalink)
Default Scanner Problem
I want to buy a new Scanner just for scanning some paintings & some photographs.My budget is Rs.5000.
Please tell me which should i buy..??
Also tell me how much a Home Level MFD will cost???
Thank U
http://mobiveda.com
vineetrocks2005 is offline
Old 24-01-2007, 06:37 PM   #2 (permalink)
shantanu's Avatar
Default Re: Scanner Problem
Benq or CANON
shantanu is offline
Old 24-01-2007, 06:44 PM   #3 (permalink)
Which one is the best..what do u say about HP Scanners??
Can u also quote the prices of these Scanners
Thank U
http://mobiveda.com
Old 24-01-2007, 06:46 PM   #4 (permalink)
a_g = JPKN
s18000rpm's Avatar
this may help. *Review Hp All in one 1410 Printer*
try HP F380 (renamed from 1410 series to F380)
ASUS K53SV SX520D + BF3
s18000rpm is offline
Old 24-01-2007, 06:52 PM   #5 (permalink)
Hey can anyone tell me the approximate cost of the HP All in One 1410 Printer ???
Old 24-01-2007, 06:52 PM   #6 (permalink)
a_g = JPKN
s18000rpm's Avatar
HP Printers
around 4.5k or less
Old 24-01-2007, 06:57 PM   #7 (permalink)
Hey thanks @s18000rpm
__________
What is the difference between Hp All in one 1410 Printer & HP F380 ??
Are they same ???
Last edited by vineetrocks2005; 24-01-2007 at 06:57 PM. Reason: Automerged Doublepost
Old 24-01-2007, 07:05 PM   #8 (permalink)
a_g = JPKN
s18000rpm's Avatar
just the name been changed.
othe than that everything is same
i've HP 1402 All in One (2 years old), till now no problems faced. So you can by a HP without any tension.
try to get one under some offers, like free Cartridges, photo paper...
Old 24-01-2007, 07:10 PM   #9 (permalink)
Hey i am bit confused...!
Can u tell me in PSC what does Copier mean???
http://mobiveda.com
Old 24-01-2007, 07:13 PM   #10 (permalink)
a_g = JPKN
s18000rpm's Avatar
you can take Xerox copy.
just put the paper on the Scanner, press copy, a copy of that is printed.
Old 24-01-2007, 07:21 PM   #11 (permalink)
Thanks...
So at last should i go for HP F380 or look for something else
http://mobiveda.com
Old 24-01-2007, 07:26 PM   #12 (permalink)
a_g = JPKN
s18000rpm's Avatar
it depends on you.
why not see a demo of these products.
my suggestion would be the HP F380.
Old 24-01-2007, 07:29 PM   #13 (permalink)
ok
thanks for ur support
http://mobiveda.com
