core duo is 32 bit. it will not support 64 bit , if you want to switch to 64 in future then
buy atleast core 2 duo. check processor no. because at same speed they have different FSB. lower FSB professor are cheap.
i would suggest DELL. you can customise it at there site.they will clear show detail of each parts.
http://www1.ap.dell.com/content/prod...=in&l=en&s=bsd
if you can strech your budjet then:
DellTM InspironTM 6400 Notebook
Intel® CoreTM 2 Duo Processor T5500 (2MB Cache, 1.66GHz, 667MHz FSB)
Genuine Windows VistaTM Home Basic
15.4" Wide Screen XGA TFT Display (1280x800 res.)
512MB DDR2 SDRAM at 533MHz (1X512MB)
80GB1 5400RPM SATA Hard Drive
Free upgrade to 1GB 533MHz DDR2 SDRAM (2x512MB)
Free upgrade to DVD Burner
Rs 4,000 Cash Off
E-Value E-Value Code :Q540208
From
Rs.49,900
Price after savings (Price excludes taxes and delivery charge)
Expires 23-02-2007.
