Old 24-01-2007, 04:56 PM   #1 (permalink)
Default help sansa e250 drivers
recently i bought sandisk sansa e250
my computer installed the driver of sansa e250 mp3 player itself,
but now when i reinstalled the XP, it refuses to install the driver itself, i tried the CD which comes with the mp3 player, but the driver is not provided in it.
the driver is not provided on the site either.
what should i do?
keep it cool
nd4spd is offline
Old 24-01-2007, 05:12 PM   #2 (permalink)
You gave been GXified
gxsaurav's Avatar
Default Re: help sansa e250 drivers
what error u get when installing the driver from the CD provided?
sansa e250 can work like a removable storage, with no drivers required.
about.me/gxsaurav
gxsaurav is offline
Old 24-01-2007, 08:14 PM   #3 (permalink)
Security Exp
47shailesh's Avatar
Hey see in ur device manager that if ur USB are UP or not..generally XP bt defaut(orignal).. Pz chk and then reply also tell us ur mobo code..
We Love Once, And When We do We do it Well
47shailesh is offline
Old 30-01-2007, 02:28 PM   #4 (permalink)
i have asus A8N-VM csm
i think its due to the non updated windows XP,
cause it didn't gave any problem when i used it at my home on the very same PC, but with updated Windows.
i want to know that which update i should run so that windows recognizes my mp3 player.
No ERROR was given.
cause the cd provided don't have the driver in it. it only have the file conversion software.
keep it cool
nd4spd is offline
