Old 24-01-2007, 08:11 AM   #1 (permalink)
Default Hard disk dead ?
When connecting my 80 gb hard disk some pcs dosent load any operating sys , instead it goes to the safe more or norrmal mode selection , even if selected safe mode or other ,this keeps repeating, tried in diffrent jumper position still the same..
but the size of the hdd apears in bios ..
is my hdd dead ?
Please help
eureca_eureca is offline
Old 24-01-2007, 10:16 AM   #2 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
Default Re: Hard disk dead ?
some pcs???
that means u haev tried it on diff pc's??
wizrulz is offline
Old 24-01-2007, 08:13 PM   #3 (permalink)
shantanu's Avatar
No your HDD is not dead ! this is a common problem with sata when your os corrupt its drivers and you have to copy the drivers once again to hdd !! or you can format the system and then try reinstalling with a floppy or cd in which drivers are their for your sata controllers. PRess F6 during the boot screen when xp boots from cd means on the blue screen when it says that press F6 to install drivers
shantanu is offline
Old 24-01-2007, 08:44 PM   #4 (permalink)
GaurishSharma.com
gary4gar's Avatar
Of what compny it is??
if seagate then try this:http://www.seagate.com/support/seatools/
gary4gar is offline
Old 24-01-2007, 09:12 PM   #5 (permalink)
Security Exp
47shailesh's Avatar
Exclamation Re: Hard disk dead ?
Ye Kya Kiya bhai......
We Love Once, And When We do We do it Well
47shailesh is offline
Old 24-01-2007, 10:58 PM   #6 (permalink)
Its not sata hdd , its a samsung . i ve tried it as a slave ,then it should have worked , Is there any issues of drivers when installed on a diffrent comp with diffrent hardware config ?
or is it a changce of hdd failure ?
Old 24-01-2007, 11:11 PM   #7 (permalink)
I Always Prefer 1080p
techtronic's Avatar
SATA and IDE are different types of Hard Disks
Of these,which is yours ?
techtronic is offline
Old 24-01-2007, 11:22 PM   #8 (permalink)
shantanu's Avatar
SATA IS A TYPE NOT A MAKE !!
SAMSUNG SATA OR SEAGATE SATA OR WD SATA OR HITACHI SATA OR OTHER COMPANIES SATA
its serial ATA type of transfer
shantanu is offline
Old 25-01-2007, 02:21 PM   #9 (permalink)
YEa i was telling its a normal samsung (IDE) ,not sata
would sata and ide not work together ?
Would a damaged hdd show its size in bios
Last edited by eureca_eureca; 25-01-2007 at 02:34 PM. Reason: Automerged Doublepost
Old 26-01-2007, 01:28 AM   #10 (permalink)
shantanu's Avatar
SATA AND IDE CAN WORK TOGETHER!! AND A DAMAGED HDD (with bad sectors) shows its size in BIOS AND GETS DETECTED BUT NOT A DEAD ONE
shantanu is offline
Old 26-01-2007, 05:34 PM   #11 (permalink)
The Transcendental
Man just run checkdisk after booting from dos or a live cd.
Happens if you restart frequently directly or power down improperly.
I have a Samsung IDE too. Had this problem in my early days.
Happens especially if u r using fat32, accumulates several errors over time. switch to ntfs if you can (especially your boot partition)
:::::::::: When freedom is outlawed, only outlaws will have freedom ::::::::::
..:: Free Radical ::.. is offline
Old 26-01-2007, 10:17 PM   #12 (permalink)
Yup i got some answers finally to not panic any more , thx shantanu
but how to get it working back again ..like free radical said i can try a live cd but i dont much around dos..BTW how do i go to dos unless i can reach upto an os .all i get is to select the diffrent modes to start windows ..like normally and other options , selecting other option brings back to the same option over and over again .I will have to try a live cd.and yes its a fat partition on c drive ..
and other cause and ways to get it back working ?
Old 26-01-2007, 11:41 PM   #13 (permalink)
shantanu's Avatar
so now do one thing download this samsung DM from my site just click the link :
http://www.thecomputernext.bravehost...ds\samsung.nrg
this is a bootable cd image which you have to burn on cd and boot from it ,
and then click on utilities and do a zero fill drive (quick one)
then in maintenence cilck on update master boot record(mbr) and then when its done restart. insert the bootable XP cd and then try running the installation.
THIS BOOT IMAGE PROVIDED ABOPVE WILL ONLY BURN IN NERO..
shantanu is offline
Old 27-01-2007, 05:22 PM   #14 (permalink)
The Transcendental
or you may google for hiren's boot cd
You can even run Win98 off it!
I dont know whether it is a completely legal thingy so can't give you the links
Old 27-01-2007, 10:49 PM   #15 (permalink)
i just did a search and found it has got a bulk of free wares and tools in it , thx
hope i will be able to get back my hdd soon
__________
shantanu the link u have given me is not working
Last edited by eureca_eureca; 27-01-2007 at 10:49 PM. Reason: Automerged Doublepost
