Old 24-01-2007, 03:17 AM   #1 (permalink)
anarchy0x's Avatar
Default best MOBO with E6600
Which is a good MBO with E6600? n what features i should look for while looking for a MBO? like nvidia sli etc.. n wat do they mean??
anarchy0x is offline
Old 24-01-2007, 10:21 AM   #2 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
Default Re: best MOBO with E6600
first think what u require ur PC for...r u gamer?? a graphics designer??
or just daily use??
then u can decide abt requiremnt of sli...
SLI means having two identical graphics card interconnected..so that u get double speed.
DEF=>Scalable Link Interface (SLI) is a method developed by NVIDIA for linking two (or more) video cards together to produce a single output. SLI is an application of parallel processing for computer graphics, meant to increase the processing power available for graphics. With SLI, it is possible to roughly double the amount of graphic complexity that can be handled by a computer just by adding a second identical video card
now u want best mobo for E6600 it would be
INTEL D975XBX2
ASUS P5WDH DLX
MSI D975X PLATINUM V.2...
wizrulz is offline
Old 24-01-2007, 10:24 AM   #3 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
BEst MOBO at the Moment is P5WDH Deluxe from ASUS. Ranked No.1 At all places. Yes it has Cross Fire for ATI and not SLI for Nvidia
More Info : http://www.asus.com/products4.aspx?m...3&l2=11&l3=248
Review at Anandtech
http://forums.anandtech.com/messagev...&enterthread=y
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 24-01-2007, 10:56 PM   #4 (permalink)
Security Exp
47shailesh's Avatar
Have a look to this
http://www.thinkdigit.com/forum/show...8&postcount=20
We Love Once, And When We do We do it Well
47shailesh is offline
Old 25-01-2007, 12:32 AM   #5 (permalink)
Rising ApocalypsE
keith_j_snyder2's Avatar
Well best motherboard....if u ask me i 'de say EVGA 680i(nVidia chipset)
keith_j_snyder2 is offline
Old 25-01-2007, 12:18 PM   #6 (permalink)
Security Exp
47shailesh's Avatar
EVGA 680i is based on NVIDIA 680i NForce which i have mentioned... Both have same feature..
