Old 23-01-2007, 10:46 AM   #1 (permalink)
Default TV tuner 4 widescreen 20inch LCD
Guys can you please suggest a TV tuner for widescreen 20 inch lcd monitor 1680 x 1050.
Is external better or internal?
I got Gemini LCD TV tuner (external) but it does not work with the set top box, it does not pick up signal from STB, does these tuner require anything different to work with the set top boxes or DTH services like dish tv or tata sky?
ranjan2001 is offline
Old 25-01-2007, 09:44 AM   #2 (permalink)
Default Re: TV tuner 4 widescreen 20inch LCD
Waiting for the answers & reading other post I get to know that mine does not have recording option, so I am returning it.
I need a internal/external (whichever u suggest) with recording option so when I am out missing the TV program, it can record TV using media center in mpeg 3/4 or divX.
Pinaccle is one of them but not sure how will it work with my STB & 20 inch LCD combo.
Need suggestions.
Old 25-01-2007, 10:03 AM   #3 (permalink)
Get a Powercolor ATI Theater 550 Pro or a Hauppauge WinTV 150/250. Either will cost around 4.5 grand. Both are MCE compatible and have hardware encoding support.
C2D E8400@3.8, P5N32-E SLI, 2GB Cellshock DDR2 1000(4-4-4), 8800 Ultra SLI, 2.7TB storage, CM Stacker 830, TT 1200W, Dell 2005FPW, Lots of Audio HW.
Ch@0s is offline
Old 25-01-2007, 10:56 AM   #4 (permalink)
R these Vista compatible? I need to find these here in delhi.
How about the Pinnacle TV cards?
Thanks
Old 25-01-2007, 12:39 PM   #5 (permalink)
^^Both are vista compatible. Pinnacle sucks. It uses a 9bit ADC whereas the ones I suggested have a 12bit ADC. Both of these are waaay better in video quality.
Ch@0s is offline
Old 25-01-2007, 01:03 PM   #6 (permalink)
premsharma's Avatar
Where do we get these? Please indicate dealers ....
premsharma is offline
Old 25-01-2007, 01:10 PM   #7 (permalink)
I called up few dealers but they dont have any of these, will check with few more specilly for the ATI theater, the specks looks nice.
Old 02-03-2007, 10:47 AM   #8 (permalink)
I have a Hauppage WinTv PVR150 with licenced win mce, also have a IR Blaster(got with the card). I need some info on how to control the stb(TATA SKY) using mce remote.
vakubhai is offline
Old 02-03-2007, 10:54 AM   #9 (permalink)
shantanu's Avatar
yoiu can also visit www.windowsmarketplace.com and search for tv tuners of good quality
shantanu is offline
Old 02-03-2007, 11:15 AM   #10 (permalink)
The High 5 Flyer
sam9s's Avatar
Ranjan check this out..
http://www.pinnaclesys.com/PublicSit.../PCTV+110i.htm
I dunno if this would suffice your request....but pinnacle has got one of the best personal video recording system.
sam9s is offline
