Old 22-01-2007, 09:32 PM   #1 (permalink)
"MKIN WAY 2 android"
Orionz's Avatar
Default !!Power Calibration Error!! SUC*S
Hi guys
I am using SAMUNG SW-252 CD-RW to write the Cds
The prob is whenever i am going to write the cds Nero giving me
the massage POWER CALIBRATION ERROR.
I do all Possible Tricks.
I have updated Latest FIRMWARE.
1-Changed The media
local CD r---->Samsungs Cdr------>LG------SONY.
Nothing happens.
2-chacked on all writing speeds
52x.....32x.....24x.....16x......4x
Nothing happens.
3- Tried DifferN Burning Softwares.
AS* Feeling Like RIPPED.
What the hell Is This. FU*K OFF ***SAMSUNG***.
They Are Worst.
Orionz is offline
Old 22-01-2007, 09:34 PM   #2 (permalink)
Arsenal_Gunners's Avatar
Default Re: !!Power Calibration Error!! SUC*S
http://www.gidforums.com/t-1805.html try this
And I agree with you.Samsung drives are the worst.
Arsenal_Gunners is online now
Old 22-01-2007, 09:35 PM   #3 (permalink)
Orionz's Avatar
Pls Help Gusy
I have burned only near of 100 discs.
i dont want to loose my money.
Orionz is offline
Old 26-01-2007, 04:13 AM   #4 (permalink)
The Transcendental
I second that.
Check if the drive is in warranty and get a replacement. Also check if the cable is ok. else your may need some repairs.
:::::::::: When freedom is outlawed, only outlaws will have freedom ::::::::::
..:: Free Radical ::.. is offline
Old 26-01-2007, 07:26 PM   #5 (permalink)
Medic on Call!!
medpal's Avatar
power caliberation errors suggest only two faults:
faulty or fake or substandard media
second dying drive. I also had a samsung it showed power caliberation error one day and died on me suddenly.
IMHO you have to change your drive.
medpal is offline
Old 26-01-2007, 08:19 PM   #6 (permalink)
shantanu's Avatar
Power calibration error comes when the drive cannot provide subsiquent power for writing or the disc cannot be determined by write head correctly,
Your Drive is Dying so make a relacemant if its under warranty or get it repaired by a mechanic (cost in service center rs. 200 for servicing and power IC rs.120) total of 320/- and your drive is back again.
and if you can spend then purchase a combo or DVDRW
shantanu is offline
Old 27-01-2007, 12:19 AM   #7 (permalink)
::cyborg::'s Avatar
@Orionz dude i also has \d the same problem
listen 1st u calm down
and 2nd install nero 5.5 or install the version of nero which was given to at the time u bought ur writer
and 3rd try writex media i think they are good
if nothing happens
straight away go to samsung service centre and bang the writer on their heads.
:)) - KEEP SMILING
::cyborg:: is offline
Old 27-01-2007, 11:51 AM   #8 (permalink)
Hanging, since 2004..
tarey_g's Avatar
I am answering this same question in this forum for the 5th time .
Answer is sell the stupid drive(as i did), if no one is buying it throw it in garbage where it belongs. Last thing to do is the take a oath of never ever buying a 'Samsung' optical drive.
Windows 8 ? :lol:
I have a better OS installed, people call it Windows7 8-)
tarey_g is offline
Old 28-01-2007, 08:55 AM   #9 (permalink)
Tushar.bar's Avatar
Angry Re: !!Power Calibration Error!! SUC*S
If you do not have warranty do not i repat do not repair it just give your bro for playing.Please take my advice b cos i have two samsung optical drive.
Tushar.bar is offline
Old 28-01-2007, 11:26 AM   #10 (permalink)
::cyborg::'s Avatar
lol
:)) - KEEP SMILING
