Old 22-01-2007, 08:14 PM   #1 (permalink)
the end begins....
Default which processor is better??
hi guyes i want to buy a new pc. but i am confused in case of processor should i buy processor with higher clock speed and HT technology or a core 2 duo processor or pentium D.
so plese tell me which is best amung these coz core 2 is very new.
my budget is around 7000rs.
thanks.
sanyaldk is offline
Old 22-01-2007, 08:22 PM   #2 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
Default Re: which processor is better??
in that budget u can get pentium dual core
925 (4MB L2 cache 3.0Ghz 800MHz FSB 65nm)
But u cannot get CORE 2 DUO .....
wizrulz is offline
Old 22-01-2007, 08:35 PM   #3 (permalink)
shantanu's Avatar
Yeah you cannot get C2d, So go for the above 3.0 PD
shantanu is offline
Old 22-01-2007, 08:39 PM   #4 (permalink)
Google Bot
Pathik's Avatar
i think u can get pentium D 940 in that price...
Pathik is offline
Old 22-01-2007, 08:40 PM   #5 (permalink)
Tech Geek's Avatar
you cant get C2D for 7K
you can get pentium dual core 945 (4MB L2 cache 3.4Ghz 800MHz FSB 65nm) Rs7000
Tech Geek is offline
Old 22-01-2007, 09:15 PM   #6 (permalink)
Romeo + Lucifer = ME
codename_romeo's Avatar
get a PD 3.4ghz with 4 mb L2 cache
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
codename_romeo is offline
Old 22-01-2007, 10:37 PM   #7 (permalink)
Go for core 2 duo processor... just add Rs.2000 to your budget and get Intel C2D E6300 which costs 8900...
navino87 is offline
