Old 22-01-2007, 08:10 PM   #1 (permalink)
Exclamation Laptop LCD(CIRCUIT PROBLEM)
I have a compaq notebook its Lcd's Backlight is not burning.
the probable cause is INverter PCB....
if somebody can provide me this circuit i am ready to buy..........
contact in my email id powerkushal@gmail.com
or Call 0091-3252-316606
__________
contact in my email id is powerkushal@gmail.com
thanks
kushals is offline
Old 22-01-2007, 08:35 PM   #2 (permalink)
Laptoping
Sourabh's Avatar
Default Re: Laptop LCD(CIRCUIT PROBLEM)
The inverter is the most common problem in laptops. Local notebook repair shop would be able to fix it too. I guess you can see a faint image of the display on the screen, if yes then it must be entirely due to the faulty inverter. Otherwise it would be a screen issue.
If you think you can do it yourself, you can google for shreelaptops. Contact them, they even have a ebay.in store where they sell notebook components including lcd panels and stuff. But getting it done from a technician would be better. What if it doesn't get solved after ordering it?
Sourabh is offline
Old 22-01-2007, 08:37 PM   #3 (permalink)
shantanu's Avatar
Yeah that is true !! because then the responsibility will be of the technician and not you!!!
shantanu is offline
