| Forum |
#4 (permalink) |
a_g = JPKN
=>Click Start, then right-click on My Computer, and then select Properties.
=>On the My Computer properties window, click on the Hardware tab, and then click Device Manager. =>Click on the plus ( +) sign next to Imaging Devices and locate the webcam item in the device list. =>If the webcam is not listed, do the following activities to install the driver using the webcam driver recovery. =>Click Start, click All Programs, click PC Help & Tools, and then click HP Application Recovery. =>Select Driver installation and click Next. =>Select the HP Webcam 1000 driver from the list, and click Install. If the webcam is listed under Imaging Devices but there is a red X on the icon, the webcam is disabled. See figure below. Disabled Webcam Icon ![]() =>To enable the webcam, right-click the HP WebCam 1000 icon and click Enable. The webcam icon should display on the Desktop. More @ this HP webpage - HP Notebook PCs - Resolving Problems with the Built-in HP Webcam Solve a problem - HP Pavilion dv2117tx Notebook PC Useful HP stuffs - HP Notebook PCs - Checking Your Notebook PC Using the HP System Health Scan
★----------�----------★ _ ★----------�----------★ |
#5 (permalink) |
thanx but there is no webcam in driver installation list..........
__________ as I did system recovery so after that I'm not finding webcam icon anywhere
I\'m the game & want to play Last edited by salils; 21-01-2007 at 03:54 PM. Reason: Automerged Doublepost |
#6 (permalink) |
a_g = JPKN
did you check in the "Device Manager", whether the cam is listed.
the drivers are supposed to be there. Coz its factory Set stuffs. __________ oh you did the sys. recovery. did you Delete the Recovery Partition. coz these drivers are stored there. __________ btw did you run Full System Recovery or Standard Recovery
★----------�----------★ _ ★----------�----------★ Last edited by s18000rpm; 21-01-2007 at 04:03 PM. Reason: Automerged Doublepost |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
