Old 21-01-2007, 01:15 AM   #1 (permalink)
Resident Fanatic
Manshahia's Avatar
Question CD Drive Tray doesnt come out
When i press the button to open the tray to put a CD it doesnt come out.
I hav to take a screwdriver and put it at some place frm where pressure can be put to open it up.
Some times just giving two three slaps opens it.
Sometimes it opens at its own.
Wat is the problem?
Manshahia is offline
Old 21-01-2007, 01:30 AM   #2 (permalink)
Super Hero - Super Powers
n2casey's Avatar
Default Re: CD Drive Tray doesnt come out
Happens with most of the CD-ROMs.
First solution:
Open CD-ROM carefully & clean it. (Will only work for some days)
Second solution:
Always keep a CD in ur CD-ROM. (Will work till ur CD-ROM dies)
Minds are like Parachutes They work best when open
n2casey is offline
Old 21-01-2007, 01:34 AM   #3 (permalink)
Resident Fanatic
Manshahia's Avatar
If i will keep a cd in cdrom then whenever i start my PC it will take time to detect wether cd is bootable or not.
AT startup it will start the cd once.
It wud b revolving in cdrom most of the time, making the lens more weak.
Old 21-01-2007, 01:39 AM   #4 (permalink)
n2casey's Avatar
Well I have some solution for that also.
  • Take a fully transparent CD (found in 10/100.. CD Packs).
  • Take a scratched/waste CD & put it opposite i.e. upside down. Is that necessary to put the CD in a way that marking/printing remains upside???
n2casey is offline
Old 21-01-2007, 02:02 AM   #5 (permalink)
Resident Fanatic
Manshahia's Avatar
cudnt get the point. SOrry .
Plz elaborate more.
Old 21-01-2007, 04:27 PM   #6 (permalink)
n2casey's Avatar
Cool Re: CD Drive Tray doesnt come out
Plz elaborate more.
Well, I was saying that use any one option from these.
  • A fully transparent CD means CD which haven't any media writing material on it.
  • Take an old Digit CD & put in CD-ROM having its printed side (where Digit logo & contents r printed) down, so that CD-ROM doesn't read it.
n2casey is offline
Old 21-01-2007, 06:29 PM   #7 (permalink)
Still Shining!
Lucky_star's Avatar
For a temporary solution use a long pin (a safety pin or a needle will do), and put it in the tiny hole You see below the drive tray. Push the pin inside and you will feel something obstructing. Push a little more and the drive will open.
Some dust has accumulated on the drive mechanism. If you can then open up the drive and apply some vaseline to the moving parts.
What's your drive model and how old is it?
Nokia N86 8MP
Lucky_star is offline
Old 21-01-2007, 07:42 PM   #8 (permalink)
Resident Fanatic
Manshahia's Avatar
its LG around 15 months old
Old 21-01-2007, 10:11 PM   #9 (permalink)
Still Shining!
Lucky_star's Avatar
Ok, LG and Samsung drives are prone to problems and in most of the cases its the tray that causes the problem.
Did you try the methods I suggested ?
Nokia N86 8MP
Old 21-01-2007, 10:14 PM   #10 (permalink)
n2casey's Avatar
Using a pin everytime is not good coz it damage CD tray lock (it's just made of hard plastic & pin can damage it). The pin hole is provided for emergency only. That's why I didn't suggest u this method.
n2casey is offline
Old 21-01-2007, 10:17 PM   #11 (permalink)
Still Shining!
Lucky_star's Avatar
Smile Re: CD Drive Tray doesnt come out
I knew that is for emergency cases only. I just informed him that its possible.
Opening up the drive and a careful oiling will solve most of his problem.
Nokia N86 8MP
Old 21-01-2007, 10:33 PM   #12 (permalink)
titun
Posts: n/a
n2casey's solution is the best one.
My SONY DVD-ROM drive behaves exactly the same way. I always keep a unused CD in it. It really comes out at once everytime.
And if u disable boot from CD drive, it will not search for bootable CD while booting , as simple as that. And by the way why will revlove all the time when you are not going to read from it ?? Mine doesn't.
Old 21-01-2007, 10:55 PM   #13 (permalink)
Just another linux lover.
subratabera's Avatar
Here is a possible solution for your cdrom...
Open your cdrom tray and look inside carefully. You will see a rubber belt. Just change this rubber belt with a new one. That will solve your problem...
Today is a most unusual day, because we have never lived it before; we will never live it again; it is the only day we have.
(Registered Linux User #432737 - subratabera.blogspot.com)
subratabera is offline
Old 21-01-2007, 11:10 PM   #14 (permalink)
ApoorvKhatreja's Avatar
In my case the rubber belt was OK, the problem was with the disc to which the rubber band was tied. Due to all that opening and closing, it had worn out and got jammed and tight. Just get it serviced (If you have some skill you could do it yourself, cause I did it). A little bit of oiling or replacement of the disc (to which the rubberband is tied) will definately solve the problem. Most of these problems arise with Samsung and LG, not with BenQ and Sony .
http://apoorvkhatreja.blogspot.com
ApoorvKhatreja is offline
Old 21-01-2007, 11:11 PM   #15 (permalink)
ANGEL OF DEATH
NIGHTMARE's Avatar
Post Re: CD Drive Tray doesnt come out
yes subratabera is right or second things r gears change it if not working properly go to the any TV repair and give it to him
Dell 15z + WD 2TB
Dell Studio 1555 + WD 1TB
iPhone 4 32 GB
Samsung Galaxy S2 White
Good Desktop Power Of C2D + 4850
NIGHTMARE is offline
Old 21-01-2007, 11:12 PM   #16 (permalink)
Still Shining!
Lucky_star's Avatar
Originally Posted by ApoorvKhatreja
..... A little bit of oiling or replacement of the disc (to which the rubberband is tied) will definately solve the problem. Most of these problems arise with Samsung and LG, not with BenQ and Sony .
Yah, exactly. That's what I am saying.
Nokia N86 8MP
Old 22-01-2007, 01:10 PM   #17 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
instead use a small software 2 open CD\DVD tray ...........
search 4 software in tutorials section, was posted long back ........
ax3 is offline
