Old 20-01-2007, 10:28 PM   #1 (permalink)
bow chicka bow wow
neeru_igi's Avatar
Question onboard displays:which one is better??
which one's better?
atiX200 or nvidia6150
also in a (un)related matter.is the onboard nvidia 6150 better than an XFX geforce 5200(128 MB agp 8x )
thx in advance
neeru_igi is offline
Old 20-01-2007, 10:51 PM   #2 (permalink)
Stalker's Avatar
Default Re: onboard displays:which one is better??
well....nv 6150 has shader model 3.0 & is capable of playing the latest games
while x200 is shder model 2.0
__________
the 6150 is better than the x200 by a very small margin.....but the 6150 core is not powerful enough to take full advantage of shader model 3
| C2Q Q6600 G0 | Intel DG33FB | 4 GB Corsair 6400C5G DDR2-800Mhz | XFX 8800GTX | CM Extremepower 600W | 250GB Seagate HDD | Lite-ON 1635S DVD RW | Logitech MX-518 | Zalman RS6F | APC RS 800 |
Stalker is offline
Old 21-01-2007, 01:12 AM   #3 (permalink)
premsharma's Avatar
Exclamation Re: onboard displays:which one is better??
I don't think there is any huge difference. I feel ATI is Better. This shader model 3.0 and 2.0 was also compared by digit in earlier graphic cards and Nividia was rated superior because at that time ATI had only 2.0. I think it was a bluder because in practical there was no noticeable difference.
Onboard always better from ATI. I believe ATI is coming up with RX 1200 onboard on 965 chpset mobos.
premsharma is offline
Old 22-01-2007, 09:17 PM   #4 (permalink)
Romeo + Lucifer = ME
codename_romeo's Avatar
X200.........i can tell coz i am using it
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
codename_romeo is offline
Old 22-01-2007, 09:28 PM   #5 (permalink)
rahul_becks23's Avatar
well ,make a decision depending on ur other computer peripherals .
rahul_becks23 is offline
