Old 20-01-2007, 06:18 PM   #1 (permalink)
TeCh Blogger : Gtechinfo
gau_pppu's Avatar
Default how to do hibernate
how will i do hybernate
gau_pppu is offline
Old 20-01-2007, 06:30 PM   #2 (permalink)
Arsenal_Gunners's Avatar
Default Re: how to do hibernate
Just take your blanket and sleep under a rock....
In computer,first you need to enable hibernation.
to do this
right click on desktop
select properties.
select screensaver tab
click on power at the bottom right.
select hibernate tab.
check the enable hiber.box
apply>ok>ok
now you are ready to hibernate
open start menu
select turn off computer
when the turn off computer box appears press shift
this will turn the standby option into hibernate.
click it while pressing shift.
done
Arsenal_Gunners is online now
Old 20-01-2007, 06:47 PM   #3 (permalink)
TechTin.com
ravi_9793's Avatar
To put the system in to hibernation:-
1]Make sure that the system is hibernation enabled. To confirm that, Click the Start button, go to Run menu and type in Powercfg.cpl and click OK. In the Power Options Propertiesclick Hibernate tab and make sure that Enable hibernation option is checked. Click OK/Apply.
2]Now Click the Start button, go to Run menu and type in %windir%\System32\rundll32.exe powrprof.dll,SetSuspendState and click OK.
To put the system in to Stand by :-
1]Make sure that the system is hibernation disabled. To confirm that, Click the Start button, go to Run menu and type in Powercfg.cpl and click OK. In the Power Options Propertiesclick Hibernate tab and make sure that Enable hibernation option is unchecked. Click OK/Apply.
www.9zap.com/forums -> Indian Webmaster Forum
whost.in - Web Hosting Offers
thinkdigit.com/forum/showthread.php?t=109137
TechTin.com
ravi_9793 is offline
Old 21-01-2007, 11:06 AM   #4 (permalink)
gau_pppu's Avatar
after doing hibernate can i switch off the main power line
gau_pppu is offline
Old 21-01-2007, 11:35 AM   #5 (permalink)
Still Shining!
Lucky_star's Avatar
Yah, of course. You can switch off the power.
When you start your computer again, it resumes from where you left.
Nokia N86 8MP
Lucky_star is offline
Old 21-01-2007, 12:52 PM   #6 (permalink)
Tech Geek's Avatar
use it wisely as it occupies a lot of space
Tech Geek is offline
Old 21-01-2007, 02:16 PM   #7 (permalink)
a_g = JPKN
s18000rpm's Avatar
instead of pressing Shift & clicking Hibernate, you can just press H when the Turn Off Computer widow appears.
__
s18000rpm is offline
