Old 20-01-2007, 02:21 AM   #1 (permalink)
Default DVD Writter Problem
Hello ppl
I have a problem with my DVD writter-Sony DRU820A.
It is around 2 months old. The problem is that when i eject the tray, the tray comes out and goes bak in automatically. No spyware problem, I even did a fresh Windows reinstall and it persists. Also a Linux boot dvd ritten with the writter reads in DVD ROM and not in Writter.
What could be the probelm. Should i get it replaced/serviced???
Thanks in advance
Cheers
sudhix is offline
Old 20-01-2007, 02:24 AM   #2 (permalink)
Waiting for 3 Miracles...
saurav29's Avatar
Default Re: DVD Writter Problem
no offense dude did you say 2 months old.....
hmmmm.........
you can
1) try to be quick insert dvd or cd quickly........
2) press eject again.......
3) If everything fails...........
SERVICE CENTER DUDE ......... GET IT SERVICED.......
Peace
Raj
saurav29 is offline
Old 20-01-2007, 09:51 AM   #3 (permalink)
Stalker's Avatar
the mechanism of the tray could be faulty ..get it serviced
i won't worry abt the linux thing, it sometimes shows my lite-on DVD writer as a CD drive
| C2Q Q6600 G0 | Intel DG33FB | 4 GB Corsair 6400C5G DDR2-800Mhz | XFX 8800GTX | CM Extremepower 600W | 250GB Seagate HDD | Lite-ON 1635S DVD RW | Logitech MX-518 | Zalman RS6F | APC RS 800 |
Stalker is offline
Old 20-01-2007, 09:29 PM   #4 (permalink)
Romeo + Lucifer = ME
codename_romeo's Avatar
Service centre i say
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
codename_romeo is offline
Old 21-01-2007, 01:14 AM   #5 (permalink)
premsharma's Avatar
Exclamation Re: DVD Writter Problem
Get it replaced and not repaired.
premsharma is offline
