| Forum |
#1 (permalink) |
www.indianangler.com
when the going gets tough, the tough go.....fishing!!! |
#2 (permalink) | |
Bayerische Motoren Werke
Go for Creative Inspire 5200 5.1 (It is around 3800-4000)
File not found. Should I fake it? (Y/N) |
#4 (permalink) |
Romeo + Lucifer = ME
JBL ENCOUNTER (2.1) Rs7600
Altec VL-251 5.1 Rs4000 CREATIVE INSPIRE 5.1 Rs3800 CREATIVE INSPIRE 6.1 Rs5100 CREATIVE INSPIRE 7.1 Rs6700
Sony Vaio CW26FG Nokia E 63 + Iphone 3GS Nikon D3000 + 50mm f/1.8 + 70-300mm Lens |
#6 (permalink) |
Try me
HMM YOU CAN GO FOR F n D 5.1 350 watt rms , mind blowing outout power and DOLBY PROLOGIC IIx supported and THX certified in only 3500/- GREAT NAA.. i was too amazed but i am using it right now
Forum rules: http://www.thinkdigit.com/forum/announcement.php?f=3 Blog at : http://thecomputernext.com/blog |
#7 (permalink) |
wat stands for F n D??? alongwit tat ne sound card is essential or it shall do fine otherwise????
#8 (permalink) |
If you are on a stringent budget but still want quality, your choice should be Creative, I say this so because you get the best after sales service with creative, same is the case with Logitech too but their speakers are a bit pricey.
Anyways, for a 5.1 system look for Creative SBS 580 (5.1) - Rs.3818/- in kolkata http://www.creative.com/products/pro...&product=14095 Creative Inspire 5200 (5.1) - Rs.3477/- in kolkata http://www.creative.com/products/pro...=25&product=55 Creative Inspire P5800 (5.1) - Rs.6031/- in kolkata http://www.creative.com/products/pro...&product=10596 |
#9 (permalink) |
Try me
F n D are very nice 5.1 and they are Quite good as compared to Creative ...
no need of a external sound card but you must have on board... and if you want THX sound and dolby full effects then you can purchase a creative sound card (coz the speaker creates only virtual enviornment for dolby) and its THX
#10 (permalink) |
Macboy
Logitech Z-5300 should fit your budget if extended to 11k. They are THX certified though not DD or Prologic...
Never heard of F n D though...
I'm like a bird... |
#11 (permalink) |
Either Logitech Z5300 or Altec FX5051 if you can extend your budget to around 11 grand. With the latter you don't need a soundcard as it has USB input.
C2D E8400@3.8, P5N32-E SLI, 2GB Cellshock DDR2 1000(4-4-4), 8800 Ultra SLI, 2.7TB storage, CM Stacker 830, TT 1200W, Dell 2005FPW, Lots of Audio HW. |
#12 (permalink) |
pedal to metal
altec lansing FX5051 wud be a gr8 buy but u might not get multichannel surround in direct3d games in USB mode but u can overcome that by using the analog connections while playing such games...
my vote goes to altec FX5051 ENJoy...
your "attitude" is your best friend... |
#14 (permalink) |
i think i should follow da advise of chaos...since he's a audiophile...thanks guys....but wat is dis brand called????? F n D????? ne answer????
| Bookmarks |
| Thread Tools | |
| Display Modes | |
