Old 19-01-2007, 03:35 PM   #1 (permalink)
Blended Pain's Avatar
Default New comp for 50-60 K
Hi, I need help picking out a config for a new comp, my budget is around 50-60k.
It should be good enough for gaming. I play games like NFS Carbon+Most Wanted, GTA, Thief 3, FIFA, PES, Q4, Halo etc.
One thing to keep in ming is I'm not much (or not at all) of a overclocker so if some card is cheaper just because i doesn't allow overclocking, I would prefer it. BTW how much RAM is the norm nowdays? Also please suggest sufficent power I will need.
Blended Pain is offline
Old 19-01-2007, 03:57 PM   #2 (permalink)
Default Re: New comp for 50-60 K
Intel C2D E6300 8.5k
MSI P965 Neo4 6.5k
Transcend 2x1 GB DDR667 RAM 10k
Seagate 250GB SATA2 HDD 3.8k
Radeon X1950Pro 13k
Any cabinet+Antec 550W PSU 5k
Liteon DVD writer 1.9k
Samsung 940BW 19" LCD 13.5k
Logitech c'less kbd+mouse 1.7k
Altec Lansing ATP3 2.5k
Total Rs. 66,400
drvarunmehta is offline
Old 19-01-2007, 09:21 PM   #3 (permalink)
Romeo + Lucifer = ME
codename_romeo's Avatar
drvarunmehta..........nice config
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
codename_romeo is online now
Old 19-01-2007, 09:25 PM   #4 (permalink)
Tech Geek's Avatar
if you want to reduce the price take
only 1 1 GB ram
seagate 160 GB (7200 RPM) Rs2700
Tech Geek is offline
Old 19-01-2007, 09:38 PM   #5 (permalink)
Stalker's Avatar
^^& maybe then u can go 4 a C2D e6400/6600
will an antec 550W PSU cost only 5k?? i had expected it to be much higher
| C2Q Q6600 G0 | Intel DG33FB | 4 GB Corsair 6400C5G DDR2-800Mhz | XFX 8800GTX | CM Extremepower 600W | 250GB Seagate HDD | Lite-ON 1635S DVD RW | Logitech MX-518 | Zalman RS6F | APC RS 800 |
Stalker is offline
Old 19-01-2007, 10:02 PM   #6 (permalink)
MSI P965 Neo4 6.5k
Radeon X1950Pro 13k
Total Rs. 66,400
Instead of going for LCD go for CRT monitor and use the money to buy E6600.
E6600 is much more good performer than E6300. For more information read DIGIT Nov 2006 issue.
And if you can wait till June this year lower and mid range Dx10 cards form nVIDIA and ATi are coming.
Its best if you have some motherboard which have onboard graphics card like DG965RY or DG965WH.
Both motherboard will cost you around 7K.
These onboard graphics cards (X3000 from intel) are not so good but the Dx10 cards are worth waiting for.
abhipal is offline
Old 19-01-2007, 11:17 PM   #7 (permalink)
Stalker's Avatar
if u want to wait for dx 10 but need a gud gfx solution temporarily, try the palit x1600pro.....its a pretty decent card & retails for 4k. u can save money on that instead of buying the X1950 & later get a dx10 card
Stalker is offline
