Old 19-01-2007, 02:13 PM   #1 (permalink)
Default BeSt DvD WrItEr
i intend to nbuy a dual layer dvd writer... can someone tell me which is the best dvd writer and what's the price in new delhi...
ashishkhetriwal is offline
Old 19-01-2007, 03:45 PM   #2 (permalink)
Security Exp
47shailesh's Avatar
Default Re: BeSt DvD WrItEr
Iomega is the best DVD writer you can get...
We Love Once, And When We do We do it Well
47shailesh is offline
Old 19-01-2007, 04:08 PM   #3 (permalink)
premsharma's Avatar
Question Re: BeSt DvD WrItEr
None can beat Plextor. But may be costly. Other brands are in range of 1800 to 2200. LightOn is very impressive, supports wide spectrum of Media including local brands. Asus can be one more to look upon. Avoid Sony & Samsung, i would rather suggest.
I have three of them Pioneer, Plextor & Light ON. Light On is the newest one with me. Pioneer is about to die as it is arround 4 years old.
Can check reviews of DVD-RW at cdfreaks.com
premsharma is offline
Old 19-01-2007, 05:37 PM   #4 (permalink)
Security Exp
47shailesh's Avatar
Sry, forgot to mention about Plextor ya it's the best.. Though expensive..
Plextor & Iomega are high duty devices...
Old 19-01-2007, 06:19 PM   #5 (permalink)
Romeo + Lucifer = ME
codename_romeo's Avatar
This is the reply if u ask me:
Plextor > Iomega > Liteon > Sony/HP > Benq > Samsung/LG
But if u want value for money then Liteon/HP/Sony
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
codename_romeo is offline
Old 20-01-2007, 01:50 AM   #6 (permalink)
premsharma's Avatar
Exclamation Re: BeSt DvD WrItEr
No confusing just go for LightOn, if looking for cheapest & best [SST], If money is no problem, then go for Plextor.
Old 20-01-2007, 10:06 PM   #7 (permalink)
can someone tell me what's da price of plextor in new delhi...
Old 20-01-2007, 10:59 PM   #8 (permalink)
ashisharya's Avatar
u can check deir site
To follow the path:
look to the master,
follow the master,
walk with the master,
see through the master,
become the master. -Zen
ashisharya is offline
Old 21-01-2007, 12:59 AM   #9 (permalink)
premsharma's Avatar
whose site? If you know their indian site, please letus know
Old 21-01-2007, 02:11 AM   #10 (permalink)
LOL newer plexies are rebadged benqs. Get either a benq 1650/55 or LG H10N/H12N/H42N (not 20N/22N) or Asus 1608sp3 which is a rebadged Pioneer 111D.
C2D E8400@3.8, P5N32-E SLI, 2GB Cellshock DDR2 1000(4-4-4), 8800 Ultra SLI, 2.7TB storage, CM Stacker 830, TT 1200W, Dell 2005FPW, Lots of Audio HW.
Ch@0s is offline
Old 21-01-2007, 02:18 AM   #11 (permalink)
premsharma's Avatar
and whose rebadges are sony?
Old 21-01-2007, 02:42 AM   #12 (permalink)
The Sony DRU-830A is rebadged a Samsung and the GW-120A or whatever is a rebadged Optiarc.
Ch@0s is offline
Old 21-01-2007, 02:52 AM   #13 (permalink)
premsharma's Avatar
Who are original manufactures? Like I heard Pioneer makes OEM for 2-3 companies and Light ON for another 2-3 companies including sony etc
Old 21-01-2007, 04:54 AM   #14 (permalink)
ANGEL OF DEATH
NIGHTMARE's Avatar
Post Re: BeSt DvD WrItEr
sony and samsung having same quality. i prefer go for liteon or asus. after DRU-830 sony not making good writer i replace two writer and get a samsung writer its also low quality
Dell 15z + WD 2TB
Dell Studio 1555 + WD 1TB
iPhone 4 32 GB
Samsung Galaxy S2 White
Good Desktop Power Of C2D + 4850
NIGHTMARE is offline
Old 21-01-2007, 03:06 PM   #15 (permalink)
premsharma's Avatar
Cool Re: BeSt DvD WrItEr
That is correct. Sony & Samsung are not favourite here amy time. I too Light ON.
Old 21-01-2007, 04:24 PM   #16 (permalink)
@ashishkhetriwal if u r in banglore than its ok but if stay in other state than never go for LITEON as its service center is only in banglore
Dhiraj Thakur
thakur.dheeraj(@)gmail.com
Desi-Tek.com is offline
Old 21-01-2007, 06:32 PM   #17 (permalink)
Eazy's Avatar
Last week I bought the Liteon 165H6S Lightscribe 16x and the LG H42N 18x witers and they are both pretty good though I find the LG has the edge in writing speed and quality over the Liteon. The LG cost me 1700/- and the Liteon 2950/-. I have read that the Liteons have a slight problem with -R media. I dont use -R media so I cannot confirm this.
Eazy is offline
Old 21-01-2007, 06:50 PM   #18 (permalink)
premsharma's Avatar
I use only -R media with lighton and no problem. Rs 2950???? or 1950. i don't think its so costly. Presently LG is also OK.
Which speed edge? Do you mean you are writing at 18X? Which media? Speeds do not make big difference as you are never going to write above 4X or 8X on local media. It won't work properly. Safe writing only at 4X. Lot of incompatibility issues with this or that media & writers are prevalent.
__________
Only you need a service center in your place if you have samsung writers or Hard disks. they are most frequent failures.
Apart from this, todays breed of writers hardly last for a year or so. Therefore, should consider it as piece for 1 year.
Old 21-01-2007, 08:30 PM   #19 (permalink)
Resident Fanatic
Manshahia's Avatar
How abt BENQ guys?
Manshahia is offline
Old 21-01-2007, 11:38 PM   #20 (permalink)
Eazy's Avatar
The Liteon 165H6S is a LightScribe writer like I mentioned - this costs 1K more then the regular writers.
If I burn same lot of discs the LG burns it a bit faster than the Liteon and when I check its quality with CDSpeed the LG burned disc shows a better result. I also confirmed the superior reading capability of the LG with commercially pressed media.
I have burned over 2 hundred Moser 8x media at 12x with no coasters in my BENQ 1640. I have checked the burn quality after completion with CDSpeed and I have not seen an unacceptable loss in quality caused by the burning of the 8x MBI media at 12x.
I have flashed modded firmware for my BENQ and Liteon which allows me to increase the burn speeds over the media's rated speed - I got these from Links in the CDFreaks forums.
I dont have the patience to burn at 4x
Eazy is offline
Old 22-01-2007, 12:15 AM   #21 (permalink)
premsharma's Avatar
LightScribe then fine. I can't take chances of burning at higher speeds, as I use writing for games. I have no experience on BenQ. Ofcourse cdfreaks is the place where I also look for these things
Old 22-01-2007, 01:46 AM   #22 (permalink)
Duh... there are two sony drives in the market...the 830A is made by samsung and the GW-120A(not sure of exact model no) is made by Optiarc which is a Sony-NEC consortium.
Ch@0s is offline
Old 22-01-2007, 07:45 AM   #23 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
LiteOn or Benq for me!
vijay_7287 is offline
Old 22-01-2007, 04:44 PM   #24 (permalink)
Can any one please mention the model of latest DVD Writer from sony and liteon which does't have lightscribe...
navino87 is offline
Old 22-01-2007, 08:09 PM   #25 (permalink)
Eazy's Avatar
The newest Liteon models I think are the LiteOn 18A1P and 20A1P DVD-Writers - but I could not find them locally. What they sell here are older models. The Lightscribe models have the same name except that the "P" in the model name is exchanged with an "H"
The Liteon writer I bought last week has a manufacturing date of Feb 2006 and the unit was sealed !!!
Eazy is offline
Old 22-01-2007, 08:39 PM   #26 (permalink)
Try me
shantanu's Avatar
Sony Sony Sony Sony Sony Sony Sony Sony Sony Sony
Forum rules:
http://www.thinkdigit.com/forum/announcement.php?f=3
Blog at : http://thecomputernext.com/blog
shantanu is offline
Old 22-01-2007, 09:47 PM   #27 (permalink)
Eazy's Avatar
Originally Posted by shantanu_webmaster
Sony
Do Sony make any of the writers themselves ? I have read at CDFreaks that some of the Sony writers are made by Liteon and some were by BenQ and other makers too supply to Sony.
Eazy is offline
Old 22-01-2007, 10:36 PM   #28 (permalink)
Try me
shantanu's Avatar
YOU KNOW ONE THING :
SONY IS THE BEST I EVER USED.. and it makes no difference to me that who makes it, and THE PEOPLE WHO CRITISIZE Cannot make SONY DIE
Forum rules:
shantanu is offline
Old 24-01-2007, 03:48 AM   #29 (permalink)
The Transcendental
Thumbs up Re: BeSt DvD WrItEr
Will definitely recommend a LiteOn (i.e. if you consider yourself as a poweruser and flash modding doesn't give you angina.)
It is the best community supported drive due to its resonable costs (checkout cdfreaks.com). Thus you'll find a range of features (not possible without a great deal of trouble in other brands) like RPC1 mode (region protection circumvention : google for LtnRPC)
I myself own one - gives excellent quality burns (though i may say it is somewhat slow as compared to other brands, but then you can always use Omnipatcher to increase burn speeds by hacking the firmware/ i.e. overspeeding).You can even add fancy multi colored LEDs for burn indication in selected drives (check codegurus, chemical brothers for hacked firmwares)
CPRM circumvention strategies may be possible in the near future (They say it can be done already. Damn Sony for DRMing our drives, ooh do I hate DRM)
Stay away from lg, benq if your pocket allows it and samsung is a definite NO.
Get a plextor if you can (better write quality and features, no frills , out of the box drives that just work great ) - worthy if you have deep pockets and want a good quality product with all the latest features though Liteon is definitely recommended if you are a control freak and hacker wannabe. If you can wait a few months, liteon is gonna relese 20x dvdrws in jan2007. May be available in a couple of months in India.
:::::::::: When freedom is outlawed, only outlaws will have freedom ::::::::::
..:: Free Radical ::.. is online now
Old 24-01-2007, 11:40 AM   #30 (permalink)
Eazy's Avatar
@Free Radical ..... sadly Plextor have stopped produvtion of CD/DVD writers....
http://wesleytech.com/plextor-exits-cd-dvd-markets/
Eazy is offline
