| Forum |
#1 (permalink) |
I need some dealer contact info who can get this ram ASAP I need 2x 1GB |
#4 (permalink) | ||
The High 5 Flyer
#5 (permalink) |
10 days of waiting I still cant find the 1 GB Transcend DDR2 800 Mhz RAM, no one has it.
I have the following choice Buy 667 1GB x 4 sticks (will it overclock same as 800?) Wait for 800 to arrive (I am on loaned ram have to return it) Get CORSAIR XMS2 2GB (2 x 1GB) from US or Get the 2x1gb cellshock 1000 DDR2 from US or 2x 1gb crucial ballistix DDR2-1000 which works better as I need to overclock & the comp will do graphic editing mostly apart from usual surfing & music in the background. in reference to another thread here CAS latency of the ram which one should I buy? |
#6 (permalink) |
^^check xtremesystems and u'll know the answer to what to get
C2D E8400@3.8, P5N32-E SLI, 2GB Cellshock DDR2 1000(4-4-4), 8800 Ultra SLI, 2.7TB storage, CM Stacker 830, TT 1200W, Dell 2005FPW, Lots of Audio HW. |
#8 (permalink) | |
The High 5 Flyer
If you want to get it from US get a 2x1gb cellshock 1000 DDR2. Waiting for 800mhz could also be an option if you know a dealer who can give you some kind of assurance about the RAM availability. |
#9 (permalink) |
If you are interseted in overclocking the RAM that you should go for is the one mentioned below.
Kingston KHX8000D2/1G. The site address is http://www.kingston.com/HyperX/products/khx_ddr2.asp |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
