Old 18-01-2007, 10:30 PM   #1 (permalink)
ApoorvKhatreja's Avatar
Default Memory compatibility - DDR
I have a D101Ggc Intel Motherboard which supports only DDR RAM. I just wanted to know that if I wanted to add another stick of memory to the other slot that is currently empty, what are the conditions so that it is compatible with the previous stick of RAM?
ApoorvKhatreja is offline
Old 18-01-2007, 10:33 PM   #2 (permalink)
Super Hero - Super Powers
n2casey's Avatar
Default Re: Memory compatibility - DDR
Clock speed/frequency must b same for both RAM sticks.
Minds are like Parachutes They work best when open
n2casey is offline
Old 18-01-2007, 10:42 PM   #3 (permalink)
So there isn't any issue with the size? I mean can I combine a 1 GB stick with 128 MB?
Old 18-01-2007, 10:44 PM   #4 (permalink)
n2casey's Avatar
Yes u can.
n2casey is offline
Old 18-01-2007, 10:45 PM   #5 (permalink)
Romeo + Lucifer = ME
codename_romeo's Avatar
u can definitely add.....but then it is not advisable as both the modules will take different voltages.....so if u can then add a 1 gb stick n remove the 128 mb stick
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
codename_romeo is offline
Old 18-01-2007, 11:07 PM   #6 (permalink)
How about a 512 + 256 ? And could you eloborate on the problems could arise with the different voltage intake?
Old 18-01-2007, 11:35 PM   #7 (permalink)
n2casey's Avatar
It will work fine if both sticks have same clock speed.
Regarding voltage, in a condition of different working voltage, ur system can hang, errors related to memory can occur or system will not boot.
I faced these errors when I was trying to upgrade my friend's PC.
n2casey is offline
Old 19-01-2007, 12:19 AM   #8 (permalink)
Thanks.
