Old 17-01-2007, 12:58 PM   #1 (permalink)
digiFriend's Avatar
Question can 2 SMPS be started automatically?
if we could start two smps automatically then it will beats all high end smps in performance and cost. manually we can start other smps by joining wire no 14 green and any black wire.
(2 frontech 400w smps cost about 850 Rs. output: 400w+400w=800w, even if true output is 500w than also it would be much cheaper.)
you never know what you can do until you try
digiFriend is offline
Old 17-01-2007, 03:48 PM   #2 (permalink)
No pain....No gain
john_the_ultimate's Avatar
Default Re: can to SMPS be started automatically?
It can be done just use one of these connectors.
john_the_ultimate is offline
Old 17-01-2007, 09:36 PM   #3 (permalink)
Where will you accommodate the second SMPS in the cabinet, with proper air outlet?
V.Prem Kumar
janitha is offline
Old 18-01-2007, 10:21 AM   #4 (permalink)
Case Mod - 60% ||||||----
spynic's Avatar
its poss wen u doin a case modd..
ull req a 12V relay in order to start the 2nd smps
spynic is offline
Old 20-01-2007, 10:54 AM   #5 (permalink)
digiFriend's Avatar
thanks : john the ultimate. i was looking for something like that.
now starting the search for such cable.
Old 20-01-2007, 11:31 AM   #6 (permalink)
Proud Core i7 Owner
g_suresh_mps's Avatar
so there will be No problem Here after ......
Can i Implement this ???
g_suresh_mps is offline
Old 20-01-2007, 02:37 PM   #7 (permalink)
I had in fact considered doing this long back when only low powered units were available but could not try due to lack of time. I think there should not be any problem other than accommodating the second one and a circuit to simultaneously start the second one by shorting the green and black pins.
I think the Mobo, Processor, RAM, PCI and PCIe cards etc will be powered by one and HDD, FDD (if any) ODDs, fans etc can be powered by the other one.
V.Prem Kumar
janitha is offline
Old 20-01-2007, 05:28 PM   #8 (permalink)
assasin's Avatar
I already hav 2 SMPS running in my system.
assasin is offline
Old 20-01-2007, 06:46 PM   #9 (permalink)
spynic's Avatar
if ure ready to take some risks.. its fine..
spynic is offline
Old 20-01-2007, 11:21 PM   #10 (permalink)
dissel's Avatar
@john_the_ultimate
Please let me know where I find this cable in Kolkata ?
Any shop name/address will be helpful.
dissel is offline
Old 21-01-2007, 12:22 AM   #11 (permalink)
spynic's Avatar
dunno if u wud get it here.. but if u dnt.. u can do it urself.. but tht involves a lil wiring(srtipping&joining)
spynic is offline
Old 21-01-2007, 01:44 AM   #12 (permalink)
No pain....No gain
Originally Posted by dissel
@john_the_ultimate
Sorry dissel did not find this thingy in Kolkata..........but that was long time back maybe now its available. Will inform you if I am able to get it.
