Old 16-01-2007, 11:38 PM   #1 (permalink)
Alive Again...
satyamy's Avatar
Question Processor + Motherboard Needed in 5500/-
I have Rs. 5500 remaining
I want a Processor & Motherboard in this amt of money
Pls suggest me which one i can buy
Also if possbile tell me the mobo which has onboard graphics n sound
Pls help..............?
satyamy is offline
Old 16-01-2007, 11:40 PM   #2 (permalink)
shantanu's Avatar
Default Re: Processor + Motherboard Needed in 5500/-
IF AMD go for AMD Sempron 2800+ for rs. 4400 with ASUS mobo with PCIex slot ..
you can also buy a GPU if you extend rs. 500 means a 6200tc 256 mb for rs. 1900/-
shantanu is offline
Old 16-01-2007, 11:42 PM   #3 (permalink)
premsharma's Avatar
Cool Re: Processor + Motherboard Needed in 5500/-
Remaining means ????????? What did you spend other monies on? These are two main components, you mean you have bought other components before these two?
premsharma is offline
Old 16-01-2007, 11:47 PM   #4 (permalink)
Alive Again...
satyamy's Avatar
remaining means
currently i had rs. 20000/- (cant increase it so pls dont tell me increase budget)
so i planned to buy
160 GB HDD - Rs. 2500/-
512 RAM - Rs. 2500/-
DVD Writer - Rs. 2000/-
Cabnit - Rs. 1000/-
KB, Mouse, Speaker - Rs. 1000/-
17" Flat Monitor - Rs. 5500/-
Only have 5500 remaining
n need Processor + Motherboard
Pls suggest me an Intel Config
satyamy is offline
Old 16-01-2007, 11:48 PM   #5 (permalink)
Still Shining!
Lucky_star's Avatar
LOL
Nokia N86 8MP
Lucky_star is offline
Old 17-01-2007, 12:09 AM   #6 (permalink)
Alive Again...
satyamy's Avatar
or u can do this way suggest me a good config under 20k
17" Flat Monitor is complusory rest u can decide
satyamy is offline
Old 17-01-2007, 12:57 AM   #7 (permalink)
shantanu's Avatar
Thumbs down Re: Processor + Motherboard Needed in 5500/-
Intel Seems A Trouble In 5500/-
shantanu is offline
Old 17-01-2007, 12:59 AM   #8 (permalink)
premsharma's Avatar
I don't think that is enough, unless you go for celeron based. Or U can try some PIV 2.6 porcessor [506] 1MB L2 cache 2.66Ghz 533MHz FSB Rs3600 and motherboard ASROCK 865 GV Rs 2100. Even this one becomes 5700. Prices are indicative and may vary from place to place. Nehru place may have even less prices than this for these components
Old 17-01-2007, 01:05 AM   #9 (permalink)
shantanu's Avatar
AND HAVING THAT MUCH OF TIGHT MONEY YOU CANT HAVE A GOOD FUTURE PROOF PENTIUM BASED PC but a celeron is what you could get..
shantanu is offline
Old 17-01-2007, 10:32 AM   #10 (permalink)
Hanging, since 2004..
tarey_g's Avatar
Dont buy prescott sh1t. AMD has good options in this range. Good intel processors start from core 2's
Windows 8 ? :lol:
I have a better OS installed, people call it Windows7 8-)
tarey_g is offline
Old 17-01-2007, 10:50 AM   #11 (permalink)
premsharma's Avatar
Exclamation Re: Processor + Motherboard Needed in 5500/-
What a nice way to put it. I also think so Core 2 Duo is better. Though do not have any experience on AMD so far
Old 17-01-2007, 11:08 AM   #12 (permalink)
assasin's Avatar
^^^ AMD proccys r very good specially in ur price range as compared to Intel.Go 4 AMD Sempron 2800+.I've used a 2600+ and performance was very good.
AMD Sempron 2800+ & Asus K8-VVM = 5k
assasin is offline
Old 17-01-2007, 07:36 PM   #13 (permalink)
Alive Again...
satyamy's Avatar
ok sir if intel is not possible in 5500 than i will go for AMD
can u pls tell me
What is the speed of AMD Sempron 2800 or
of which Intel Processor AMD Sempron 2800 equals to
is it equals to Intel 2.6Ghz Processor
or is it equals to Intel Celeron 2.xx something something..........??
Pls help................?
Also if possible tell me the Price of Intel 2.8HT & Its compatible board
satyamy is offline
Old 17-01-2007, 09:16 PM   #14 (permalink)
rajasekharan's Avatar
hi....for your money its better you go with amd ...it offers better performance than a similary priced intel...., you will not regret it...
__________
hi.....for this money you better go for amd.....it offers better performance than intel at similar price...you will not regret it...
Make a day good , and another day good , and another ...a happy lad is "born" from you :)
Last edited by rajasekharan; 17-01-2007 at 09:16 PM. Reason: Automerged Doublepost
rajasekharan is offline
Old 18-01-2007, 02:50 PM   #15 (permalink)
assasin's Avatar
can u pls tell me
Performance of AMD Sempron 2800+ is far better compared to any Intel Celeron proccy.It also beats the P4 ina few benchmarks specially in gaming.
I dont think u'll get P4 2.8GHz HT,but u'll get Pentium D 820 (2.8GHz).
P4 3GHz + Intel D101 = 8.2k approx
P4 3GHz + Intel D102 = 8.7k approx
Pentium D 820 + intel D101 = 9k
Pentium D 820 + Intel D102 = 9.5k
Pentium D 820 + Intel D945GNTL = 11.2k
If u can increase ur budget go 4 AMD Athlon + nVidia/ATI chipset mobo.
Hope this helps.
assasin is offline
Old 19-01-2007, 11:26 PM   #16 (permalink)
"remaining means
so i planned to buy
Cabnit - Rs. 1000/-
17" Flat Monitor - Rs. 5500/- "
First tell me if u have already bought all this
2day's prices are
160 Gb Seagate 2700
DDR 400 512 MB Trancsend RAM 2150-2200
TwinMOs should be less
DVD Writer
Sony OEM 18X 1950
SOny Box pack 18X (DRU 830) 2150
Sony Box pack 16X (DRU820) 1850-1950 -->Go 4 dis
LG Box pack 18X 1750-1850
17" non flat monitor 4700
SO I think u can go for
AMD Athlon XP 3000+ 939 pin and Asus A8V-VM (good via chipset) (not A8N-VM) for 6000/-
ashnik is offline
Old 20-01-2007, 01:48 AM   #17 (permalink)
Rising ApocalypsE
keith_j_snyder2's Avatar
Knock knock...hello....dude did u saw that...he wants something with in 5500
No one even let u touch ONLY PROCESSOR(CORE 2 DUO) with in this budget...not even E6300.
Anyways buddy u have the option to go for refurbished ones or other option is AMD 3000+ & mobo(any)
keith_j_snyder2 is offline
Old 20-01-2007, 05:05 PM   #18 (permalink)
Alive Again...
satyamy's Avatar
thanks guys u helped me a lot
i have not buyied any product as yet
the price which i have mentioned is the price i got from my dealer
well i m thinking to go for Athlon 64 3000+ & its compatible board
Thanks Again
satyamy is offline
