Old 16-01-2007, 10:43 PM   #1 (permalink)
gg_3000's Avatar
Default Cabinet Fans
As far my knowledge abt cabinet fans goes, I know that
*Rear Fan shud blow the air out
*Side and Front Fans bring air into the cabinet
Lemme know if i'm right or wrong?
But recently i saw a PC in a gaming center in which the side fan was blowing out air from the cabnet.. Is it the right arrangement?
Google - What's that?
gg_3000 is offline
Old 16-01-2007, 10:52 PM   #2 (permalink)
Super Hero - Super Powers
n2casey's Avatar
Default Re: Cabinet Fans
As I know about system fan is
  • Rear & Side fan shud blow the air out
  • Front fan shud blow the air in
Minds are like Parachutes :arrow: They work best when open
n2casey is offline
Old 16-01-2007, 10:58 PM   #3 (permalink)
shantanu's Avatar
Wink Re: Cabinet Fans
and if no front fans are their
shantanu is offline
Old 16-01-2007, 11:23 PM   #4 (permalink)
n2casey's Avatar
Talking Re: Cabinet Fans
Then Rear & Side fan for blowing the air out.
If no side fan then rear fan for blowing the air out. Simple
n2casey is offline
Old 16-01-2007, 11:27 PM   #5 (permalink)
shantanu's Avatar
and without rear
actually i meant that then side fan can blow in and rear can blow out
shantanu is offline
Old 17-01-2007, 12:34 AM   #6 (permalink)
n2casey's Avatar
Smile Re: Cabinet Fans
and without rear
I have read a subject Heat Transfer & what knowledge I got from it is, Rear & Side Fans don't have much distance btwn them so the hot air blown out from Rear Fan will get inside due to Side Fan (if is is blowing in). So both Rear & Side Fan must blow the air out.
n2casey is offline
Old 17-01-2007, 12:54 AM   #7 (permalink)
shantanu's Avatar
OK if its so .... I haD two fans installed but I removed them as i thought there was no need for cooling as my temp. didnt rise above 40 or max to 42 ,43 so ....
shantanu is offline
Old 17-01-2007, 02:57 AM   #8 (permalink)
premsharma's Avatar
Question Re: Cabinet Fans
I will say a particular job for U to do & make your temp rise to 60 degree. How is that????
premsharma is offline
Old 08-02-2007, 11:38 AM   #9 (permalink)
DO we get fans here in nehru place which can be plugged & controlled from the motherboard, I have a P5B deluxe mobo, it has 7 points to plug the fan controller but the fan in my frontech cabinet only has power cord connector.
ranjan2001 is offline
Old 08-02-2007, 04:57 PM   #10 (permalink)
Romeo + Lucifer = ME
codename_romeo's Avatar
The fans are easily available in any computer shop......u can ask them for the one which gets connected to your mobo....as far as i know they are easily available
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
codename_romeo is offline
Old 08-02-2007, 05:47 PM   #11 (permalink)
Will try tomorrow if I can get the antec 80mm
Old 08-02-2007, 05:55 PM   #12 (permalink)
Typically Front and side are intakes, rear and chimney are exhausts. Its always good to maintain a slight positive pressure. Personally I felt it always lead to better idle temps.
C2D E8400@3.8, P5N32-E SLI, 2GB Cellshock DDR2 1000(4-4-4), 8800 Ultra SLI, 2.7TB storage, CM Stacker 830, TT 1200W, Dell 2005FPW, Lots of Audio HW.
Ch@0s is offline
Old 08-02-2007, 06:03 PM   #13 (permalink)
Can u explain this? does this mean tat we should have more intake of cool air than hot outflow?
Old 08-02-2007, 08:18 PM   #14 (permalink)
^^Yup thats what I meant.
Ch@0s is offline
Old 08-02-2007, 08:56 PM   #15 (permalink)
Resident Fanatic
Manshahia's Avatar
See this image guys...
http://img183.imageshack.us/my.php?i...ed1copyfh4.jpg
This will deifnately help u.
And also this thread...
How to keep the systm Cool
Manshahia is offline
