Old 16-01-2007, 10:41 AM   #1 (permalink)
Unhappy PC does not restart
Hi everybody,
PC does not restart. PI845GLM-P Mercury mobo, P4 2.4. It shutdown and starts properly but does not RESTART. Earlier it worked fine. What may be wrong; plz help!
spp_itim is offline
Old 16-01-2007, 12:46 PM   #2 (permalink)
jatt's Avatar
Default Re: PC does not restart
which operating system u are using
ਨੋ ਗਰਲ ਫਰੈਂਡ ਨੋ ਟੈਂਨਸ਼ਨ,no girlfriend no tension,website: Punjabi.c-o.in,forum: punjabiteacher.co.cc
jatt is offline
Old 16-01-2007, 02:41 PM   #3 (permalink)
WinXp SP2, But no matter when I boot from a CD in DOS mode and press Ctrl Alt Del it does not restart also
spp_itim is offline
Old 16-01-2007, 11:19 PM   #4 (permalink)
shantanu's Avatar
check your POWER SUPPLY
shantanu is offline
Old 17-01-2007, 09:13 AM   #5 (permalink)
I noticed one more thing that "It is safe to Turn Off your computer" message appears in WinXp. But earlier didn't. Do I have to change the SMPS?
spp_itim is offline
Old 17-01-2007, 10:21 AM   #6 (permalink)
________
hash!!'s Avatar
kinda vague, but u can still try this...
disable this feature, which clears the pagefile on shutdown....
that can be done by goin to Start>Run>secpol.msc
in the dialog that opens up, go to Local Policies>Security Options
scroll to the bottom to an option called Shutdown: Clear Virtual Memory Pagefile and disable it... if that doesnt work, i guess u might have to delve into the bios settings...
phenom 9850be,M2N-E,2x2gb OCZ Platinum CL4 Edition,Leadtek 8800GTS320mb,Tagan 600w stonerock,200+320gb hdd,Optiarc20x DVDRW, SBLive! 5.1,PhilipsA2.610
"so long, and thanks for all the fish..."
hash!! is offline
