Old 15-01-2007, 06:49 PM   #1 (permalink)
thinkdigitreader's Avatar
Exclamation WHich MotherBoard is best...AsUS or InTel
Hello Friends,
I have planned to buy Intel Pentium duel core 3.4 processor, but I am confused which motherboard I have to buy ASUS or INTEL. Can u help me................?
thankX
thinkdigitreader is offline
Old 15-01-2007, 06:53 PM   #2 (permalink)
ANGEL OF DEATH
NIGHTMARE's Avatar
Post Re: WHich MotherBoard is best...AsUS or InTel
Chip Set 945,965,975 And Budget
Dell 15z + WD 2TB
Dell Studio 1555 + WD 1TB
iPhone 4 32 GB
Samsung Galaxy S2 White
Good Desktop Power Of C2D + 4850
NIGHTMARE is offline
Old 15-01-2007, 06:54 PM   #3 (permalink)
shantanu's Avatar
Default Re: WHich MotherBoard is best...AsUS or InTel
ASUS is best for AMD based mobos and MSI is also very good but for intel intel original boards are better but asus is also good
shantanu is offline
Old 15-01-2007, 06:56 PM   #4 (permalink)
Exclamation Re: WHich MotherBoard is best...AsUS or InTel
Any suitable motherboard which support DDR2 & around 5500-6000 RS
Old 15-01-2007, 07:01 PM   #5 (permalink)
^^ intel 945 and 946 chipset based motherboards are available for ur budget
signature??? :???: Let Me Think About It!!!:-D
paul_007 is offline
Old 15-01-2007, 07:03 PM   #6 (permalink)
Tech Geek's Avatar
same thought when i saw the Q
Tech Geek is offline
Old 15-01-2007, 07:07 PM   #7 (permalink)
shantanu's Avatar
yeah intel D102 is also good
shantanu is offline
Old 15-01-2007, 07:10 PM   #8 (permalink)
 Macboy
goobimama's Avatar
I find intel boards to be the best. May not be the best overclockers or high of features, but they are very stable. Intel boards also give you a good 3 years warranty which counts.
I'm like a bird... :)
goobimama is offline
Old 15-01-2007, 07:24 PM   #9 (permalink)
a_g = JPKN
s18000rpm's Avatar
@thinkdigitreader, dude, when you buy DDR2 800MHz RAM, be very careful in selecting the model, coz most of the Intel Motherboards (even the latest DG965WH) supports only upto 1.8 Volts.
i bought 1GB Corsair DDR2 800MHz RAM which runs @ 1.9 Volts, which the 965 does not support. . this RAM is costlier than the mobo itself , thats why i'm still confused on what to do, sell RAM or mobo
these types are supported in P Series. (i guess )
& Original Intel mobo's are not at all meant for Overclocking
ASUS K53SV SX520D + BF3
s18000rpm is offline
Old 15-01-2007, 07:26 PM   #10 (permalink)
shantanu's Avatar
yeah these RAMS are supported in P series and yo should sell your MOBO COZ the ram you got is a very very nice ram so dont sell it off until you have great amount of money to waste
shantanu is offline
Old 15-01-2007, 07:33 PM   #11 (permalink)
Unhappy Re: WHich MotherBoard is best...AsUS or InTel
What abt Intel D101GGCL motherboard...............?
Old 15-01-2007, 07:34 PM   #12 (permalink)
a_g = JPKN
s18000rpm's Avatar
many frnds also suggested me to keep the RAM & sell the mob.
does any P Series mobo have Onboard gfx. like GMA X3000.
& whats the cost of any P Series mobo which support LGA775 & most of c2d.
Old 15-01-2007, 07:36 PM   #13 (permalink)
shantanu's Avatar
it also is 1.8v supported
shantanu is offline
Old 16-01-2007, 01:02 AM   #14 (permalink)
The best value for money motherboard is the MSI P965 Neo. Its around 6 grand and based on the P965 chipset. It overclocks rather well too for the price and supports ram voltages upto 2.4V. However as with any P965 board, no onboard graphics... just get a cheap x300 or 6200tc.
C2D E8400@3.8, P5N32-E SLI, 2GB Cellshock DDR2 1000(4-4-4), 8800 Ultra SLI, 2.7TB storage, CM Stacker 830, TT 1200W, Dell 2005FPW, Lots of Audio HW.
Ch@0s is offline
Old 16-01-2007, 01:22 AM   #15 (permalink)
a_g = JPKN
s18000rpm's Avatar
thanks for the info @Ch@0s
but if i get a P965 based mobo, then can i install a DX10 card (like 8300gt).
Old 16-01-2007, 07:39 AM   #16 (permalink)
You can install a DX10 card in any mobo that has a PCI-E x16 slot. So the answer is yes.
Ch@0s is offline
Old 16-01-2007, 07:53 AM   #17 (permalink)
nishant_nms's Avatar
do not go for 101 go for 102 it is better and as per my opinion ASUS boards are OK.
Btw u stole my avtar
nishant_nms is offline
Old 16-01-2007, 01:57 PM   #18 (permalink)
The High 5 Flyer
sam9s's Avatar
**Off Topic**
Buddy I was waiting for an update on this.....Do not sell the RAM, sell the mobo if you have too. Go for ASUS P5B Delux or Gigabyte DS3. Awsome boards.
__________
Hello Friends,
thankX
Both boards are good and stable, but ASUS or Gigabyte boards have awsome OC capability and tons of extra features. Most Intel boards bad on OC on the other hand have onboard graphics which ASUS/Gigabyte usually lack.
When u say Pentium Dual core I presume u mean Pentium D. For that Intel would be an obvious choise since OC would not be your prime concern.
sam9s is offline
Old 16-01-2007, 02:41 PM   #19 (permalink)
a_g = JPKN
s18000rpm's Avatar
Originally Posted by sam9s
**Off Topic**
sorry sam, but i havent still tested the mobo & RAM, thats why i could not update there ("post what you puchased".. thread)
that guy (my vendor) hasnt returned yet.
I'll inform you guys when i get it tested.
dont take me wrong dude.
Old 16-01-2007, 10:42 PM   #20 (permalink)
premsharma's Avatar
Question Re: WHich MotherBoard is best...AsUS or InTel
I think this is value for money board and thus selling like hot cake. It makes a sense to buy cheap X300 graphic card as this board do not have onboard graphics.
premsharma is offline
Old 16-01-2007, 11:15 PM   #21 (permalink)
shantanu's Avatar
^ Gud One
shantanu is offline
Old 09-02-2007, 11:49 AM   #22 (permalink)
Jaas's Avatar
hi friends !
actually i'm having the pc chips motherboard ?
wat u think about that?
PUNJAB
Panj(FIVE) + Aab(Rivers) means FIVE RIVERS.
Jaas is offline
Old 09-02-2007, 09:05 PM   #23 (permalink)
Still in war with allies
ssdivisiongermany1933's Avatar
Asus are expensive a bit , but they are solid mainboards
6 yrs on no problem with Asus board
ssdivisiongermany1933 is online now
Old 09-02-2007, 09:32 PM   #24 (permalink)
shantanu's Avatar
yeah really ASUS makes quality , so i prefer them ,, In the race lie second MSI for me and then others
shantanu is offline
Old 12-02-2007, 02:22 AM   #25 (permalink)
premsharma's Avatar
I think you should sell the Intel motherbaord and try one from MSI or Asus. They have great boards.
__________
You are absolutely right. For me MSI and then Asus. Intel at the last when no other option available.
__________
Not only Intel D102 with ATI onboard is good one but it is best for those who can not afford graphic card. But sadly it do not support C2D and it is Micro ATX.
Moreover can't expect any more followups mobos in Intel platform with ATI graphics onbaord due to ATI merger with AMD.
Great injustice by ATI to those 80% with Intel platform, who were eagerly waiting for Intel chipset motherbaord by ATI with onboard gfx for C2D.
Old 12-02-2007, 02:57 AM   #26 (permalink)
 Macboy
goobimama's Avatar
I've had three machines giving problems with ASUS boards installed. Only one Asus machine is fine. All my intel original machines are working without any trouble (eight of them)....some of them 810e boards running celerons...
Old 12-02-2007, 03:22 AM   #27 (permalink)
ASUS for Enthusiast......... Intel original for normal users.........
MSI never used one........ most of ASUS boards are quad core ready and they have a version that has ATI 300 on board with DDR2 and SATA2 (3.0Gbps support) and quality service from RP tech so buy the board imported by RP tech if opting for ASUS (At least RP Tech has good service in North India) do not know about Rest.....
on_the_rocks is offline
Old 12-02-2007, 04:25 PM   #28 (permalink)
intel is my choice.
ismart is offline
Old 13-02-2007, 10:03 AM   #29 (permalink)
Jaas's Avatar
wat u think about intel 2.66 dual core intel original
PUNJAB
Jaas is offline
