Old 14-01-2007, 04:58 PM   #1 (permalink)
Q6600 Underclocked
sourishzzz1234's Avatar
Cool Cost of Core 2 Duo
What's the cost of Pentium Core 2 Duo 2.8Ghz Processor??
sourishzzz1234 is offline
Old 14-01-2007, 04:59 PM   #2 (permalink)
Tech Geek's Avatar
Default Re: Cost of Core 2 Duo
16K
Tech Geek is offline
Old 14-01-2007, 05:45 PM   #3 (permalink)
There is no 2.8 GHz C2D.
E6600 is 2.4 GHz, E6700 is 2.66 GHz and X6800 is 2.93 GHz.
drvarunmehta is offline
Old 14-01-2007, 05:55 PM   #4 (permalink)
anarchy0x's Avatar
well in that case can u explain me y intel c2d is faster than my cpu which is 2.8 GHZ HT with MOBO 865 GBF .. i always thought the more the GHZ teh faster the CPU but now imknow theres something more 2 it .. wat is it?
anarchy0x is offline
Old 14-01-2007, 06:03 PM   #5 (permalink)
More GHz is faster is true only for a particular CPU family. So amongst all Pentium 4 chips or amongst all Core 2 Duo chips, the faster the clock speed, the faster the CPU. However you can't compare the clockspeeds of differing architectures as they will have different IPC (Instructions per Clock Cycle). Finally what matters is how many instructions a CPU can execute in a clock cycle. A CPU that executes 5 instruction per clock and runs at 1GHz will be faster than a CPU that executes 1 instruction per clock cycle and runs at 3GHz. How many instructions are executed per clock cycle depends on the architecture, pipeline length and many other factors. In layman's terms, an E6300 Core 2 Duo running at 1.86GHz is faster than any Pentium D ever made (3.73GHz) since it has way better IPC...
C2D E8400@3.8, P5N32-E SLI, 2GB Cellshock DDR2 1000(4-4-4), 8800 Ultra SLI, 2.7TB storage, CM Stacker 830, TT 1200W, Dell 2005FPW, Lots of Audio HW.
Ch@0s is offline
Old 14-01-2007, 11:54 PM   #6 (permalink)
Rising ApocalypsE
keith_j_snyder2's Avatar
NICELY DONE!!!& yes u r absolutely right.AMD cores always work on lower clock speed but they are named as 3000+,3200+,3500+....so on.But a 3200+ will have a clock speed of 1.9 GHZ.They are named as 3200+ because they can perform same or more than INTEL's 3.2 GHZ processors.
keith_j_snyder2 is offline
Old 15-01-2007, 01:26 AM   #7 (permalink)
ANGEL OF DEATH
NIGHTMARE's Avatar
Smile Re: Cost of Core 2 Duo
after p-3 intel made something good and better than P-4 and P-D {820 series)
bcoz c2d execute 4 instruction per cycle under favorable conditions(idle conditions) all netburst CPU (P-4 and P-D execute Approx 2 instructions per cycle) so the c2d does approximately twice the work per MHZ then netburst CPU (give a take a few % points)
Dell 15z + WD 2TB
Dell Studio 1555 + WD 1TB
iPhone 4 32 GB
Samsung Galaxy S2 White
Good Desktop Power Of C2D + 4850
NIGHTMARE is offline
