Old 14-01-2007, 02:17 PM   #1 (permalink)
Default need infon on buyin a RAM
i own a intel 845gvsr nd its only compatible till 333mhz RAM nd i want to buy a new 512 ram but i asked all d vendors at my place dey r tellin me tht only 400 upwards r available....or u can buy second hand i just want a new one so anyone know where can i find a new one plz tell me
shikhar_kapoor143 is offline
Old 14-01-2007, 02:29 PM   #2 (permalink)
a_g = JPKN
s18000rpm's Avatar
Default Re: need infon on buyin a RAM
in which city/place you live.
ASUS K53SV SX520D + BF3
s18000rpm is offline
Old 14-01-2007, 03:11 PM   #3 (permalink)
Google Bot
Pathik's Avatar
afaik intel 845 gvsr is compatible wit ddr 400mhz ram..
Pathik is offline
Old 14-01-2007, 04:54 PM   #4 (permalink)
m frm delhi
nd i one n intel 845gvsr i checked on d site its compatible till 333 only
Old 14-01-2007, 07:02 PM   #5 (permalink)
a_g = JPKN
s18000rpm's Avatar
Digital Memory
Brand Digital Memory
Price Rs. 2400
Available At Digital IT Solutions (P) Ltd.
207, Skipper Corner,88 Nehru Place New Delhi
Phone : 26285712/13/98 , 26285713, 9811240697 *551, *547
mabe this wesite will be helpful to you. Nehru Place IT Hub
Old 14-01-2007, 07:55 PM   #6 (permalink)
DDR400 is backward compatible with DDR333. If you put in a DDR400 module in a board that only supports 333, it'll work and work at better latencies giving you more performance.
C2D E8400@3.8, P5N32-E SLI, 2GB Cellshock DDR2 1000(4-4-4), 8800 Ultra SLI, 2.7TB storage, CM Stacker 830, TT 1200W, Dell 2005FPW, Lots of Audio HW.
Ch@0s is offline
Old 14-01-2007, 08:23 PM   #7 (permalink)
Wandering in the zone ...
manas's Avatar
Buy a DDR 400 module, it will function in your motherboard at 333 MHz. You will have no problem...
Not all those who wander are lost. :D
http://www.manast.com ---- ManasT
manas is offline
Old 14-01-2007, 08:53 PM   #8 (permalink)
man i got one as my assembler by mistake brought one nd as soon i tried to use it there was three beeps nd there was no booting....nd i have another ram of 333mhz so i guess its better i get one wid d same freq
Old 14-01-2007, 08:56 PM   #9 (permalink)
a_g = JPKN
s18000rpm's Avatar
in my Intel DG965WH, three beeps mean-> RAM not compatible with m/b.
so i guess only 333MHz will work.
Old 14-01-2007, 11:42 PM   #10 (permalink)
Go to the bios and manually set the timings and clocks. Set the memory frequency to 333 and timings to 3-3-3-8. There's no reason why it shouldn't boot then.
Ch@0s is offline
Old 11-06-2007, 07:36 PM   #11 (permalink)
ashfame's Avatar
How can you say that 400mhz stick will work fine in a mobo which only supports till 333Mhz? I have heard they might smoke out
My RIG: C2D 2.0Ghz + Intel965 Mobo + OCZ Matched Pair 2X1GB DDR2 800Mhz + LG L226WTQ 22" LCD + CM 500W PSU + Palit HD 4850 512GDDR3
HOMEPAGE : http://www.ashfame.com | BLOG : http://blog.ashfame.com
ashfame is offline
Old 11-06-2007, 07:39 PM   #12 (permalink)
Wat the... Smokin???
Just reduce d RAM FSB in d BIOS to 333... It'll work fine...
iE6850 + TRU-120 + Antec120mm Trilite. ASUS P5K Deluxe Wi-Fi AP. 2Gb G.Skill DDR2 PC2-6400 (4-4-3-5). Sgt 250GB 7200.10... XFX 8800GTX 768MB. Corsair HX620. MX518. CM Cavalier. DELL SE198WFP. EP630.
gannu_rox is offline
Old 11-06-2007, 07:42 PM   #13 (permalink)
Google Bot
Pathik's Avatar
^^ u can downclock it manually...
Pathik is offline
Old 11-06-2007, 07:44 PM   #14 (permalink)
ashfame's Avatar
Last year when I was to buy a ram stick, i was told here only that 400mhz will not work!
ashfame is offline
Old 11-06-2007, 10:56 PM   #15 (permalink)
NP : Crysis
xbonez's Avatar
^^400mhz will not run at 400mhz
xbonez is offline
Old 12-06-2007, 10:02 AM   #16 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
My cosuin has Same MOBO and he too was facing RAM issues. He had 256MB at 333MHZ.
We bought 512MB 400MHZ for 1450. At first it didnt work, but switching the old RAM to other slot and New RAM on slot worked
http://www.host4cheap.org/
Sukhdeep Singh is offline
