Originally Posted by slugger
using sony media and also using 80 wire IDE cable DMA enabled (through BIOS)
will update firmware and see
Fixation error is due to media compatibility. It may be solved through firmware update. Light On is supposed to take wider range of media including locals. Trying changing your media, try out any local media for once or Writex, Eurovision etc. You would come to know that where the problem lies.
Upgarding firmware, will add support for more media & burn speeds etc. Want anything of firmware or product reviews, look at cdfreaks.com
