Old 13-01-2007, 03:18 PM   #1 (permalink)
Roy.7986's Avatar
Default Need Help To assemble pc under 30k.....
hi everyone, i m new to this forum...
can anyone help me with this config...
http://www.tomshardware.com/2006/05/..._41_ghz_cores/
this guy has overclocked this machine to 4.1ghz can anyone suggest me a similar config but under 30k coz this config is way out of my budget. plz include everything in config like kb+mouse, moniter, etc.
i'll be OC it also after few months....
Roy.7986 is offline
Old 13-01-2007, 09:04 PM   #2 (permalink)
Tech Geek's Avatar
Default Re: Need Help To assemble pc under 30k.....
processor--E6300 (2MB L2 cache 1.87Ghz 1066MHz FSB 65nm) Rs8300
motherboard--INTEL D965RY Rs6600
Harddisk--Seagate 80 GB (7200 RPM) Rs1950
ram-- DDR 400 TRANSCEND 512 MB Rs2700
graphic card-- 256 MB NVIDIA GF 7300 GT DDR3 Rs4700
montor-- LCD VIEWSONIC 17" Rs9800
DVD Drive-- LG DVD-Writer 18xD 16x, Dual Layer, 8.5GB Rs1900
speakers--CREATIVE INSPIRE 5.1 Rs3800
UPS--MICROTECH 1KVA Rs2900
mouse +keyboard-- 2K
Tech Geek is offline
Old 16-01-2007, 08:19 PM   #3 (permalink)
Roy.7986's Avatar
i have decided on this config plz give ur suggestions.
Intel Pentium D 2.8Ghz
Gigabyte GA-945G-DS3
512 MB RAM (transcend)
200GB HDD (seagate)
DVD+RW (sony)
17" TFT (BenQ)
Logitech Keyboard mouse Combo
creative 4.1 Speaker (if had some extra money)
PSU 450W
which mobo should i buy the gigabyte(above mentioned) or ASUS P5LD2-V
plz advice soon I need to buy it as soon as possible
Roy.7986 is offline
Old 16-01-2007, 08:22 PM   #4 (permalink)
Tech Geek's Avatar
go for asus mobo
Old 16-01-2007, 10:30 PM   #5 (permalink)
shantanu's Avatar
You Only Want To Go For Intel No Choice For Amd ???
shantanu is offline
Old 17-01-2007, 11:35 AM   #6 (permalink)
Roy.7986's Avatar
there r chances that i'll be runing this machine for more than 18hr a day and i heard from someone that AMD will not be able to remain stable for this much time. but if i m wrong than plz suggest me AMD config also but plz keep the budget under 30k only including everything.
Roy.7986 is offline
Old 17-01-2007, 12:57 PM   #7 (permalink)
assasin's Avatar
^^^ Dont go for Pentium D,its not a good proccy and it runs hot very quickly.As far as AMD not being stable is concerned its a myth.I'm running AMD its very stable.go for AMD Athlon X2 3800+ and Asus mobo.
assasin is offline
Old 17-01-2007, 02:00 PM   #8 (permalink)
Roy.7986's Avatar
@assasin can u plz suggest me the AMD procy+ mobo combo i have read the review of ur board Asus (M2N-MX) on http://www.newegg.com/Product/Custra...82E16813131040
and i didn't liked it so plz don't suggest that one i also dont like the micro form factor
Roy.7986 is offline
