Old 12-01-2007, 03:40 PM   #1 (permalink)
Default SATA drive failed... Trying to get back my data...
Well, my hard drive died on me... and XP won't boot. Interestingly, when I pop the drive into an external enclosure, and turn it on inside of XP, it causes the computer to crash, and restart. I spent some time searching these forums for some help, but figured after about 15 minutes, that I should start my own post.
I would love to do this recovery myself, as the data is not worth what most companies are charging to do the service for me.
Can anyone offer me some pointers as to where I might begin, given the strange crashing symptom?
Any and all help appreciated.
logan_657@yahoo.com is offline
Old 12-01-2007, 03:44 PM   #2 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
Default Re: SATA drive failed... Trying to get back my data...
first and foremost thing abt data recovery is that,... the HDD should get detected...if its not ...then sorry u urself cant do much with it.....
wizrulz is offline
Old 12-01-2007, 04:27 PM   #3 (permalink)
It could be bad sectors / damage to partition table or file system structure in such away that it will hang the system. I suggest downloading manufacture disk drive test or you can try the partition repair/data recovery software by “Salvage Data Recovery Lab Inc”. You can find it easily if you just run a search in google its name Instructions are clear while installing. Connect your drive as secondary drive on the system (not external) / or even primary and let that software run. That at least will let you know if drive is ok.
kevin_476 is offline
Old 13-01-2007, 08:27 AM   #4 (permalink)
Rising ApocalypsE
keith_j_snyder2's Avatar
yeah search on google about data recovering softwares.One of i 've used is ACRONIS DATA RECOVERY.
keith_j_snyder2 is offline
