Old 12-01-2007, 03:24 PM   #1 (permalink)
shashank_digitreader
Posts: n/a
Default PROBLEM, plz help.
I have a 2gb transcend pen drive. I am not able to eject it, whenever i try to, it show a message telling that the pendrive cannot removed now, try later. The same happenes with my digital camera. Please help me.
Old 12-01-2007, 03:26 PM   #2 (permalink)
Tech Geek's Avatar
Default Re: PROBLEM, plz help.
Just pull it out
Tech Geek is offline
Old 12-01-2007, 04:03 PM   #3 (permalink)
Living to Succeed
ajayashish's Avatar
it happens with mine also... i just pull that out
Q6600+Abit IX38QuadGT+Corsair 4gb 800mhz+ Ultra 120 Extreme+ tagan 600wts+CM690
Alienware M15 - with Gforce 460 1.5gb + 8gb DDR + i7 1.73ghz
ajayashish is offline
Old 12-01-2007, 08:24 PM   #4 (permalink)
Posts: n/a
is it safe to pull it directly? b'coze my dig cam is a new one.
Old 12-01-2007, 08:30 PM   #5 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
absolutely safe.
Or if u r that afraid & u r a fresher to computing... just restart the comp... take out the drive then
__________
that's because ur drive is a 2gb one.. maybe with lotsa stuff's in it.. and ur OS is tryin to read/identify/index ur contents... silently.
Just b sure, u r still not transferring data when u r unpluggin/removing ur drive out.
Of course, u can always pull the usb out whenever u r not transferring data... & there r simpler methods to solve ur prob (like restart explorer only)... but this is a tension-proof one to a newcomer like u...
koolbluez is offline
Old 14-01-2007, 12:45 AM   #6 (permalink)
Still Shining!
Lucky_star's Avatar
No need to restart the computer. Bring up the task manager. When the message pops up showing that "the pendrive(or Camera) cannot be removed right now", just goto processes and shutdown Explorer.exe. Now goto applications-> New Task..
Type explorer and press enter. Your device might have been removed by now.
If not, you can safely remove the hardware without that message creeping up again...
Nokia N86 8MP
Lucky_star is offline
