12-01-2007, 10:00 AM
Lost in LOST
LCD or CRT???
i wanna buy new monitor.. i mainly use pc for animation, video editing, gaming & im a movie freak.. i heard LCDs respond slow to moving ghraphics, etc. & esp while using animation softwares like 3ds max, maya.. now if my asking doesn't seem foolish, which ios best?? LCD or CRT?
12-01-2007, 10:05 AM
Re: LCD or CRT???
That's all things of past. CRT's are slowing perishing. Almost all companies use LCD for 3D softwares like CATIA V5, PRO-E, Unigraphics etc without problems. Go for LCD. No problems at all.
Kiran Kumar R
12-01-2007, 11:36 PM
Re: LCD or CRT???
Upgrading to a LCD with a good response time will benefit u. As far as CRT's go u can also have them, if u can give it the space, try opting for a 19" flat monitor from viewsonic.
12-01-2007, 11:46 PM
Waiting for 3 Miracles...
Re: LCD or CRT???
all those listed above requires staring at monitors for long times at a go.......
DUDE........ CRT's have harmful radiations and adversly effect eyes in long runs and Do yourself a favour go for TFT as you can't put a price on your eyes or Do you????????
LCD can have response time of 8ms for example samsung 740bn........ so do not worry about lagging and things like that as if you see more than 8 frames per second then it will appear moving to your eyes no matter what... General science DUDE...............
Peace
Raj
12-01-2007, 11:49 PM
Romeo + Lucifer = ME
Re: LCD or CRT???
response time of LCD u buy should be 4ms
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
12-01-2007, 11:54 PM
Google Bot
Re: LCD or CRT???
i think persistence of vision lasts abt 0.1 sec.. So the framerate shd be 12fps min .. Btw @ sagar dont worry dude.. The new lcd monitors hav very low response times.. So go 4 a lcd
13-01-2007, 08:24 AM
Rising ApocalypsE
Re: LCD or CRT???
Viewsonic is providing a 19" LCD with 2 ms response time.It is considered as gamers edition but u should grab it,its the best.
13-01-2007, 09:06 AM
Re: LCD or CRT???
Yes, VX 922. Very good monitor but a bit costlier.
V.Prem Kumar
13-01-2007, 06:20 PM
Re: LCD or CRT???
if lcd is costly get a CRT....or wait till it get cheap....get one less than 8ms...4 is ideal.....
Make a day good , and another day good , and another ...a happy lad is "born" from you :)
13-01-2007, 06:22 PM
Re: LCD or CRT???
LCD
Don't worry about the cost
13-01-2007, 10:20 PM
Re: LCD or CRT???
go for a large size quick response(very quick) LCD from brands like ViewSonic, etc. they are costly but they are worth it
13-01-2007, 10:31 PM
Lost in LOST
Re: LCD or CRT???
thanks folks.. how much that Viewsonic 19" LCD with 2 ms response time will cost me???? im located at Pune (mah)..
13-01-2007, 11:00 PM
Re: LCD or CRT???
About 2-3 months back I bought it for 17.5K but now you should get it much cheaper since cost of LCD monitors have come down drastically in the recent past.
V.Prem Kumar
13-01-2007, 11:08 PM
Re: LCD or CRT???
I also had same apprehesions. I am avid gamer. I did lot of research on the topic. Even digit had reviewed CRTs and concluded that 8ms or less should be OK enough. You can go for Samsung 19" Wide [Model 940BW]. It would cost you arround 14000 - 15000. Plenty of them are available on ebay.in
Viewsonic with 2ms response time will be very costly. Apart from response time you sholud also watch out for contrast ratio [700 0r 500:1] and brightness of 350cd/m2.
