Old 12-01-2007, 02:06 AM   #1 (permalink)
Default i want wireless fidelity!
i own a laptop and computer and have a broadband coonection(via adsl2+ modem). i want to use internet on both the computers wirelessly. i want all the details so as to establish the wi fi network at home. plzz tell me the hardwar reqired. my budget is minimal.(the lowest u can think of!)
ayush.ag is offline
Old 12-01-2007, 02:54 AM   #2 (permalink)
Living to Succeed
ajayashish's Avatar
Default Re: i want wireless fidelity!
well u cannot connect 2 machine to that modem ... so what u can do is connect both the machine wirelessly and then start internet on one with USB or Lan... and let that machine share its internet connection
Q6600+Abit IX38QuadGT+Corsair 4gb 800mhz+ Ultra 120 Extreme+ tagan 600wts+CM690
Alienware M15 - with Gforce 460 1.5gb + 8gb DDR + i7 1.73ghz
ajayashish is offline
Old 12-01-2007, 03:23 AM   #3 (permalink)
Chillum Baba
a_medico's Avatar
modem to be replaced by wireless modem/router.
The modem will emit the wireless signals. Both the terminals should be able to catch those signals.
If your laptop is Centrino, it already has wireless card - you only need to configure it. If not, then I am not sure of the other ways to convert it into wifi (?maybe usb/pcmci options are available for external wireless card)
Your computer should have a wifi card which will allow it to accept the signals from the router.
a_medico is offline
Old 12-01-2007, 03:29 AM   #4 (permalink)
Living to Succeed
ajayashish's Avatar
even then both the comp will not be able to connect directly to internet without being in network... one machine will have to have the connection and share it via network
Old 12-01-2007, 08:13 AM   #5 (permalink)
TheSaint
NucleusKore's Avatar
A good solution is to go for a combo router (broadband router + network switch). hey usually have 2-4 wired lan out and a wireless lan. Now the problem is wireless network range is not much. I have burnt my fingers with wireless networking using a netgear wap. You may get the signal at another room in your house but bandwidth drops like anything. Wireless signals do not seem to be able to bend around corners, at least that has been my experience. very disappointing. I am back to wired lan. Its very reliable ! I feel unless you go for a powerful (read expensive) air station you cannot have a wireless network AS GOOD AS a wired network in the same house.
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 12-01-2007, 10:03 AM   #6 (permalink)
Living to Succeed
ajayashish's Avatar
still u wil noot be able to make connection in both the machine as u need to dial in a BSNL connection and which cannot be done in both at the same time...
