Old 10-01-2007, 12:38 AM   #1 (permalink)
anarchy0x's Avatar
Default a RAM question
would it really make a difference in speed/or any other way if I used
3 RAMs of 256 MB (assume both RAMs are of different make so dont consider dual channel support & i do have 4 RAM slots)
OR
1 256 MB RAM & 1 512 MB RAM
the total of all is the same i.e 768MB RAM
will 512+256 be faster than 3X256??
thanks
anarchy0x is offline
Old 10-01-2007, 12:48 AM   #2 (permalink)
Living to Succeed
ajayashish's Avatar
Default Re: a RAM question
i think it will all be the same
Q6600+Abit IX38QuadGT+Corsair 4gb 800mhz+ Ultra 120 Extreme+ tagan 600wts+CM690
Alienware M15 - with Gforce 460 1.5gb + 8gb DDR + i7 1.73ghz
ajayashish is offline
Old 10-01-2007, 12:49 AM   #3 (permalink)
Still Shining!
Lucky_star's Avatar
Ram speed depends on the Clock speed of the RAM.
If u r having two RAMs of different speed and u connect them together, the net speed will equal to the RAM of the lowest speeds among them.
Nokia N86 8MP
Lucky_star is offline
Old 10-01-2007, 12:34 PM   #4 (permalink)
anarchy0x's Avatar
thanks both of u.. i know RAM will always run on the lowest speed i.e the concept of RAM backward compatiability
BUT what i mean is assuming all RAMs are of the same speed for e.g 366 will there be a difference bewteen..
3 RAMs of 256 MB
each of them have the same speed i.e 366
hope u got what i wanted 2 ask
__________
cmon any1??
Old 10-01-2007, 01:10 PM   #5 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
No there will be no added advantage....
but i i f i have a option will go of r 512 + 256...rather than 3 256 rams
wizrulz is offline
Old 10-01-2007, 01:37 PM   #6 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
Hardly Matters, which ever way you put it. The Frequency at which they work matters the most
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 11-01-2007, 01:43 AM   #7 (permalink)
What? Where? How?
escape7's Avatar
Yes it makes a difference. the thing is, your total physical memory is less than the quoted memory. EG if 5 mb is the difference then while using 2*256 mb ram u loose 5*2 mb but if you use 1*512 mb u lose only 5 mb. hope i'm clear enuf...
98% of the people using internet have started or forwarded "chain mails". If you are one of the 98%, Die a horrible death.
escape7 is offline
Old 11-01-2007, 09:32 AM   #8 (permalink)
dOm1naTOr's Avatar
But if ur mobo support dual channel setup 2 identical 2x256 or 2x512. So u get double the bandwidth.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 11-01-2007, 09:49 AM   #9 (permalink)
ramharis's Avatar
i have got this HP pavilion T630i system
P4 2.8
2x256 ddr ram
Motherboard ASUS P4SD-LA
can any body tell me if there is dual channel option in it
or give me some link how to enable dual channel (if its there for my motherboard)
Ram
Strength & Honour
ramharis is offline
