09-01-2007, 10:45 PM
SLI Query?
Do the following motherboards support nVidia SLI technology or do they only support CrossFire?
1) Asus P5B Deluxe/WiFi-AP &
2) Asus P5W DH Deluxe
thnx in advance
C2D E6600,Asus P5N32 e SLI,1GB 667mhz,Samsung 940BW,Zeb 8600GT,Seagate 250GB sata II,16x Sony(OEM) dvd RW,Zeb Anitibiotic & Platinum 500W,Microsoft desktop pro 700,bluetooth,Logitech MX Revolution
09-01-2007, 11:59 PM
Re: SLI Query?
10-01-2007, 12:46 PM
The High 5 Flyer
Re: SLI Query?
1)Asus P5B Deluxe/WiFi-AP &
2)Asus P5W DH Deluxe
thnx in advance
Both support crossfire, no SLI in both of them.....
10-01-2007, 09:26 PM
Re: SLI Query?
u guys are sure about the fact that none of them support nVidia's SLI?
__________
then is there a motherboard from Asus or any other vendor with similar specs that will have support for SLI?
thnx in advance
Reason: Automerged Doublepost
10-01-2007, 09:34 PM
Re: SLI Query?
i am sure
10-01-2007, 09:55 PM
Re: SLI Query?
^^^ thnx bro for the info...I was gonna buy the P5W DH Dlx and I returned home after my vendor told me that the mobo only supports crossfire....looking for similar mobos with SLI support can u help?
10-01-2007, 11:20 PM
Re: SLI Query?
What are your requirements and preferred companies?
11-01-2007, 09:26 AM
The High 5 Flyer
Re: SLI Query?
Why do you need SLI, I am pretty sure even if you wanna play games with insane resolutions you still can achieve with single high end machine, though for knowldge sake P5N32-SLI Delux supports SLI on a 965 chipset.
11-01-2007, 11:47 PM
Re: SLI Query?
^^Thats an NF 590i SLI chipset board not p965. Its better to get the P5N32-E SLI which is based on 680i.
C2D E8400@3.8, P5N32-E SLI, 2GB Cellshock DDR2 1000(4-4-4), 8800 Ultra SLI, 2.7TB storage, CM Stacker 830, TT 1200W, Dell 2005FPW, Lots of Audio HW.
12-01-2007, 01:24 AM
Learner
Re: SLI Query?
I'd again recommend a 680i based SLI rather than a 590i based, and i dont think SLI is all that useful for foney, as I've pointed out infinitely many times, it's a waste of money.
12-01-2007, 11:18 PM
Re: SLI Query?
thank u so much guys I'am not interested in SLI but I wanna have a slot ready for future proofing the PC.....anyways I'am a nVidia fan so I'am looking for a board that supports SLI.....is the Striker Extreme a nForce 680i based board as well?
13-01-2007, 07:23 AM
Rising ApocalypsE
Re: SLI Query?
Yes it is & best is to buy a 680i based motherboard coz it will give better performance on "8800" series Graphics card.
EVGA nForce 680i is the best motherboard & great for overclocking,if u find that...otherwise striker rules!!!
09-08-2007, 03:01 AM
Re: SLI Query?
Ok this is my problem:
Whenever I try to,
Right-click the desktop and left-click Properties.
Click the Settings tab.
Click Advanced.
Click GeForce 8600GT.
The "Enable SLI multi-GPU" option doesnt appear neither in XP or Vista.
09-08-2007, 11:28 AM
No pain....No gain
Re: SLI Query?
Because you don't have the second gfx card installed................. or is it that the cardis installed and still the option is not enabled???
09-08-2007, 12:34 PM
Re: SLI Query?
No John there is only one card installed...
Now I get it..so one will have to install two cards to get that option to pop up...
09-08-2007, 01:05 PM
Re: SLI Query?
just a question(it may seem noobish),what are the differences between SLI and crossfire??
and as NVIDIA cards are SLI ready(not crossfire) so I cant install two of NVIDIA cards in my mobo(i.e P5B Deluxe)?am i rite?
09-08-2007, 01:24 PM
Google Bot
Re: SLI Query?
crossfire is used to dual channel two ati cards..
09-08-2007, 03:52 PM
UbuntuUser
Re: SLI Query?
And in crossfire you can use 2 different cards-of the same family- (like 2600 and 2900) but in SLI you have to use same cards (like 2 8800GTSs).
Yes you are right. You can install a single Nvidia card buit SLI is not possible.
09-08-2007, 09:27 PM
#19 (permalink)
Rising ApocalypsE
Re: SLI Query?
Well actually these (SLI & X-Fire) are 2 different technologies of their respective brands.
But i have read a long time ago that nVidia is also working on SLI in which u can use 2 different graphic cards (nVidia only), i m not sure that this technology is available but they say SLI is having better performance & trusted widely and easy to the user.
Crossfire is bit complicated....for me.
But one have to have 2 SLI enabled cards to run em in SLI.
And yes u can use 2 different brands like one from XFX and another from EVGA but of same model like one 8800 GTX will be paired with another 8800 GTX!
10-08-2007, 12:47 AM
#20 (permalink)
Re: SLI Query?
hence coming back to my other question so if I may understand then as long as I dont attach the 2nd card and connect both the cards using the SLI bridge the option to enable SLI in display properties will not appear..
10-08-2007, 06:50 AM
#21 (permalink)
ToTheBeatOfUrHeart
Re: SLI Query?
To set u straight do not go for same core ie. for eg. two 8800series cards from different vendors.I have seen some reviews which resulted in degraded performance due to such a setup.Its because although the cores are same the video cards are different.Like the capacitors,ram vendor etc.
10-08-2007, 08:05 AM
#22 (permalink)
UbuntuUser
Re: SLI Query?
^^ I was having the same confusion.
cheap cards like zebronics cards might be using GDDR2 (I am not sure) whereas xfx uses GDDR3. This can degrade the performance.
11-08-2007, 12:27 AM
#23 (permalink)
Re: SLI Query?
hmm,but is it possible that they have GDDR3 printed on the box and in reality might be using GDDR2...
11-08-2007, 09:23 AM
#24 (permalink)
Re: SLI Query?
Yes........but see that you buy the same card with same specs and dont change the card maker. If u have Zebronics, go for Zebronics only.
btw i just got P5N32 E SLI, have u tried OC'ing it????
11-08-2007, 09:39 AM
#25 (permalink)
UbuntuUser
Re: SLI Query?
XFX wont be using GDDR2 and displaying GDDR3!! We cant expect such a thing from a reputed company.
#26 (permalink)
NP : Crysis
Re: SLI Query?
is there any mobo that supports sli AND crossfire??
11-08-2007, 11:31 AM
#27 (permalink)
ToTheBeatOfUrHeart
Re: SLI Query?
No there isn't.
12-08-2007, 04:40 PM
#28 (permalink)
Re: SLI Query?
Hmm,gotcha...btw my system is stock and I intend to keep it that way for a long long time
