Old 09-01-2007, 12:54 PM   #1 (permalink)
ramharis's Avatar
Default pc turns on but the monitor
Gday
my friend here has a pc a normal P4 (3.0 guess) 1GB ram well the problem is when he turns on the PC it turns on fine the POST (power on self test) works fine but there is no display on the monitor
when disconnect the monitor cable the monitor does a self diagnostics and that seems working
if this happenes he turns it off on off on off on a few times and suddenly he get the display
It works for a few days and then he has the problem again then comes the ON/OFF ON/OFF ON/OFF ON/OFF ON/OFF ON/OFF untill it works
Can some body tell me why it happens and what is the solution for it
thanks
Ram
Ram
Strength & Honour
ramharis is offline
Old 09-01-2007, 01:00 PM   #2 (permalink)
Super Hero - Super Powers
n2casey's Avatar
Default Re: pc turns on but the monitor
Check if the monitor cable is faulty.
Minds are like Parachutes :arrow: They work best when open
n2casey is offline
Old 09-01-2007, 01:00 PM   #3 (permalink)
Living to Succeed
ajayashish's Avatar
This happened to a friend of mine ... we changed the AGP and it is working fine now
Q6600+Abit IX38QuadGT+Corsair 4gb 800mhz+ Ultra 120 Extreme+ tagan 600wts+CM690
Alienware M15 - with Gforce 460 1.5gb + 8gb DDR + i7 1.73ghz
ajayashish is offline
Old 09-01-2007, 01:04 PM   #4 (permalink)
ramharis's Avatar
i will ask him to check the cable
the agp i onboard one so he cannot change it
Ram
Ram
Strength & Honour
ramharis is offline
Old 09-01-2007, 01:11 PM   #5 (permalink)
Living to Succeed
ajayashish's Avatar
Try using another AGP card
