Old 07-01-2007, 09:01 PM   #1 (permalink)
Default cpu fan
my cpu fan has started making a lot of noise. I have formatted my entire hard disk but to no avail. Any suggestions, advice ?
gambit is offline
Old 07-01-2007, 09:11 PM   #2 (permalink)
SE><IE
Posts: n/a
Default Re: cpu fan
you formatted your HDD for cpu fan. :O
Just geta a brush and brush the dust off. A new fan may be helpful
Old 07-01-2007, 09:23 PM   #3 (permalink)
Living to Succeed
ajayashish's Avatar
Default Re: cpu fan
i didn't got the link between ur CPU fan and ur HDD
ajayashish is offline
Old 08-01-2007, 12:37 AM   #4 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
Default Re: cpu fan
if ur CPU fan is making noise..what is the connection with HDD.....or u were thinking noise is frm HDD and hence formated it??
Just clean ur CPU fan with brush ( when it is off ).....
Or u want permanent solution...just search for thread abt CPU fan in TUTORIAL section
wizrulz is offline
Old 08-01-2007, 10:29 PM   #5 (permalink)
Romeo + Lucifer = ME
codename_romeo's Avatar
Default Re: cpu fan
Clean ur fan with brush.... and next time do not format ur HDD cause ur fan is making noise
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
codename_romeo is offline
Old 08-01-2007, 10:35 PM   #6 (permalink)
Default Re: cpu fan
clean Fan mate
battleman is offline
Old 08-01-2007, 11:54 PM   #7 (permalink)
Arsenal_Gunners's Avatar
Default Re: cpu fan
Hey buddy nice tip.
Arsenal_Gunners is online now
Old 09-01-2007, 06:02 PM   #8 (permalink)
samrulez's Avatar
Default Re: cpu fan
Clean the fan and screw the fan on the heat sink tightly...if its lose, it vibrates hence you get that sound..
Sam :D Rulez :lol:
samrulez is offline
Old 10-01-2007, 12:54 AM   #9 (permalink)
Default Re: cpu fan
hi guys. thanx for the suggestions but the fan still makes noise
gambit is offline
Old 10-01-2007, 12:57 AM   #10 (permalink)
Still Shining!
Lucky_star's Avatar
Default Re: cpu fan
HERE is the tutorial on how to reduce the noise from fans.
Nokia N86 8MP
Lucky_star is offline
Old 11-01-2007, 01:48 AM   #11 (permalink)
What? Where? How?
escape7's Avatar
Default Re: cpu fan
If the fan on the heat sink is loose it won't vibrate, it'll develop an air bubble and the system will crash due to thermal overheating.
98% of the people using internet have started or forwarded "chain mails". If you are one of the 98%, Die a horrible death.
escape7 is offline
