Old 07-01-2007, 08:43 PM   #1 (permalink)
blackleopard92's Avatar
Default video out ( s-video connector) problem
i have NX7300GT card and x200 onboard chipset.
and an analogue TV.
TV have composite ports for video, while NX7300GT has S-Video Connector.and x200 has a composite out.
my problem is how can i connect my PC to my TV?
i heared that s - video out can be converted to composite TV out.is it true?
also, can i use the x200's TV out while still using my GFX card?
please help
blackleopard92 is offline
Old 08-01-2007, 09:37 AM   #2 (permalink)
aka. ViKiD? <^_^>
Ambar's Avatar
Smile Re: video out ( s-video connector) problem
i dont think u can do that unless ur chipset manufacturer and gfx card manufacturer are the same.....but u can get a sv-video t6o composite connector from the market for less than 50 bucks.
_______________________________________________
do repute ppl by clickin on the balance icon on the left!
Ambar is offline
Old 08-01-2007, 10:34 AM   #3 (permalink)
DigitalImmigrant's Avatar
Default Re: video out ( s-video connector) problem
1 Use an 'S- video to composite convertor' and then connect TV-PC using 'cable for composite video ' . It is the lowest priced cable . The composite video stdd. is the lowest as it uses single line as opposed to multiple conductors .
2 U will have to set DRIVER CONFIGURATION of ur gphx card to enable ur TV as a secondary display device .
Man I sincerely suggesst u see CHIP Dec. issue . Nd tell me how u r njoyin movies on TV
DigitalImmigrant is offline
