Old 07-01-2007, 07:52 PM   #1 (permalink)
Default Help...confused!!!!!!
guys m lookin ahead 2 buy amd x2 3800+(no conroe pls) with good on-board graphics. i decided on msi k9ngm2 with 6150 chipset. But later i came 2 know bout. MCP61(p/s/v) and C51PVG chipsets. pls elaborate on these chipsets.
R these better than 6150 or shud i buy 6150 only. also 4 info 6150 provides more features. thanks in advance.
HEMANTRATURI is offline
Old 07-01-2007, 08:07 PM   #2 (permalink)
Default Re: Help...confused!!!!!!
C51PVG is based on the Geforce 6150LE and is slower than the 6150.
I suggest you buy the K9NGM2 only. It's by far the best mobo with onboard graphics for AM2.
drvarunmehta is offline
